So I am ordering some stuff from Parts Express to make Andy G's quarter wave pipes. I was thinking about also making a line array using these speakers.
32 tweeters (16 per each side)ONKYO 3/4" TEXTILE DOME TWEETER 4 OHM 16 woofers (8 per each sideONKYO 6" WOOFER 4 OHM I was thinking about crossing them over at 4000Hz using a 1st order 2-way crossover. Here is the graph for the tweeter. http://www.partsexpress.com/pdf/269-702.pdf Should I build this design? Will it sound good? Or should I just pass this idea up and just make the quarter waves only. Please let me know, as I need to put the order in very soon, in order to get them by my Spring Break (I am a college student). Thanks |
#2 |
Nevermind. I was thinking that I would benefit more from using 6" woofers instead of the 4" that was in a previous post. But I think I'm going to use the 4" that were used before because many others are doing it. I figure this way I will be able to share my findings and compare them. Thanks anyways.
-Ed |
| Coaxial car speakers for line array ? | Mikael Abdellah | Multi-Way | 3 | 23rd December 2005 03:09 AM |
| Time to buy speakers for a Line Array | Zreon | Multi-Way | 3 | 23rd October 2005 06:53 PM |
| MacIntosh XRT series line array speakers | chipco3434 | Multi-Way | 0 | 25th October 2004 04:51 PM |
| Got my line array speakers and did a quick test setup | mazeroth | Multi-Way | 12 | 24th August 2004 03:43 PM |
| Cheap PE Line Array speakers, now 49 cents! | OilStain | Multi-Way | 2 | 21st August 2004 02:12 AM |
| Page generated in 0.09023 seconds (65.51% PHP - 34.49% MySQL) with 10 queries |
