HI
I need some ide´s about makeing a music and HT sub in a large room of 350m2. There will be live mucis and cd´s played + HT over the sub. I´m thinking about 6 tempest + 3000L tuned to 18 Hz. what do you guy think ?
bass is also audio |
#2 |
or is sealed better ?
and what is the "EBS-aligned " box ? Is there somthing special with that box ? Btw. Sorry for my english
#3 |
If you're going that large, you may want to consider IB subs. (no in-room box)
Infinite Baffle subs |
#4 |
A 4'x5'x10' room is 6000L. 6 Tempests in a room like that? You're a basshead, aren't you?
#5 |
Well, that's too big a box even for EBS alignment (which is a little larger than normal). How about an IB?
#6 | ||
Although 6 Tempests in a good box with adequate power would yield impressive results even outdoors! In a 865L sealed enclosure you'd get an F3 of 35Hz and an F10 of 20Hz with Anechoic SPLs in the 120's! - Max |
#7 | |
Is the EBS alignment the best way ? Or is sealed better ? will they be loud enough in 6*865L ? I think i can fit them in under the stage.
#8 | |
will it be tight or boomy ? I will use it to play ALL kind of music+ live music and HT
#9 |
Sorry about that, I had no idea what I was thinking at the time.
#10 |
it´s ok !
But when i think about it.....
| Nasty Room Resonances in New Listening Room | TubeHead Johnny | Multi-Way | 4 | 23rd May 2009 11:13 PM |
| basic room accoustics..help design my ht room :) | JinMTVT | Multi-Way | 4 | 4th September 2007 11:35 AM |
| Big Room to Small Room | CARTRulz | Subwoofers | 1 | 21st August 2006 05:59 AM |
| Tempest help | Robertburchell | Subwoofers | 9 | 25th July 2006 05:56 PM |
| enclosure for tempest in 7x25x(3,25)m room | wingman | Multi-Way | 9 | 16th June 2004 05:12 PM |
| Page generated in 0.09338 seconds (80.25% PHP - 19.75% MySQL) with 10 queries |
