In another thread that I almost hi-jacked Sreten posted this picture. I'd like to know how the cross-sectional area is determined in a design like this. It seems like a very narrow pipe. In back-loaded horns the top of the pipe starts out similar to this but gets wider as it nears the terminus.
#2 |
I'd suggest the intention is for each vertical section to be
narrower, as you move towards the terminus. But by introducing a shielded bass driver they had to tweak the first divider giving a line profile not in any textbook. You can't see the half depth of the box but I estimate the CSA of the line to be ~ = to Sd of the bass driver, in the first section of the line. |
#3 |
Thanks, I thought that it was about Sd but it's hard to tell from the picture. I'll have to play around with this. Folks seem to like little boxes.
#4 |
Hmm, all I can do is lay a scale on the screen, but it sure appears to be a constant cross section from the first fold to the terminus, and once you subtract out the drivers, probably the first section also. The terminal cup/XO causes a constriction in the pipe, though how much of one depends on how dense the foam is.
Anyway, more than likely it was determined by the decades old rule-of-thumb to make the line's effective cross sectional area = Sd, but as MJK's work has shown, this isn't the Hot Ticket to good overall performance for most drivers. As for short, well this just means a relatively high Fb if it's not reverse tapered. Browse MJK's TL design tables to get some idea where to start. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 |
I played around with So and SL equal to Sd and got some unpleasant results. I'll keep trying.
#6 |
Try whatever the max flat Vb is for whatever Fb you chose.
GM
| I am done with AES -- a short rant. | dsavitsk | Tubes / Valves | 48 | 14th April 2012 03:17 AM |
| Interest in ZV4 short run? | Michael Rothacher | Group Buys | 38 | 6th December 2005 11:46 PM |
| Best driver for short TL | MikeFarad | Multi-Way | 9 | 10th March 2004 10:54 AM |
| How short can a TL be..? | Ian J | Multi-Way | 10 | 31st March 2003 01:03 AM |
| Page generated in 0.07364 seconds (75.17% PHP - 24.83% MySQL) with 11 queries |
