Looking at building a 110ltr sealed enclosure using the following driver:
Re HC 15" Fs: 25.7hz Qms: 7.06 Qts: 0.43 Vas: 114ltr Xmax (1way): 21mm BL: 22.6 SPL: 88.5 Basically I'm curious as to how well this would work in a sealed enclosure. I'm after quality rather than volume. Does the BL figure of 22.6 suggest that it is indeed a very good performer? |
#2 |
Assume you're talking about the Resonant Engineering HC15.
Since you're using a sealed box, I'm also assuming that you are after sound quality too, and as such I would recommend their XXX line. EDIT: Oops, skipped over the part where you said you were looking for quality. The XXX uses Adire Audio's XBL^2 technology which leads to lower distortion, so I imagine it would sound better at higher output levels. EDIT2: You can use Linear Team's WinISD Pro to calculate the output of the driver. Download from their site. |
#3 |
BTW, anybody else find the RE site to be completely superfluous? I want to go back to the days of logical text pages and the odd attractive graphic...
#4 |
the RE HC 15 costs almost half that of the XXX 15, considering their previous sale and lower used price
110 liters would actually be really good vented for the driver tuned to around 29-30hz with 35-40sqin of port, its a very nice driver with a good mix of both SQ and SPL |
#5 |
Do you already have the HC15? The most recent deal was buy two for $300, because they are being replaced. I don't know if there are many more in stock if any. As stated earlier the XXX would be better suited for sound quality but if you get the HC at a good price then its your decision whether you want to pay more or not. Currently, only the Brahma, Tumult and the XXX have Destijl's XBL^2 tech, but a few smaller drivers will be sporting it later this year.
#6 |
creative sound also has a driver that sports the technology
and "better sound quality" is completely opinion in relation to user interpretation they are rather "lifeless" drivers and some people don't like that |
#7 | |
By "lifeless" what exactly do you mean? I've heard the Brahma described as "transparent." I could see how the two could be used to describe the same type of sound. |
#8 |
heh I was actually talking about the creative sound SX 10 driver with xbl^2
I've heard them refered to as transparent but I'd describe it more as mechanical and not very musical When you listen to something you have an impression as to how it should sound in your mind - be it from live or recorded reference - and to some the driver doesn't sound like it should in their mind, some like the drivers and some don't, I've heard from both sides |
#9 | |
#10 |
Hifi is and always will be like food.
Everybody get something out of it, whether its good or bad is down to the individual. BUT: Chocalate is the exception here though, there ain't nobody gonna turn some chocolate. [waits] for the 'have to be different' crowd to dissagree |
| L-pad attenuator for midrange driver 6 1/4 inch driver | rhythmdiy | Multi-Way | 0 | 4th November 2007 03:32 PM |
| FS: Silver Iris Coaxial 15" driver pair (sans XO and compression driver) | theAnonymous1 | Swap Meet | 0 | 24th April 2007 12:09 AM |
| Driver/ driver configuration improve soundstage width | andy2 | Multi-Way | 6 | 16th June 2005 08:47 PM |
| mtm versus tm driver recommendations on project with $500 driver and xo part limit | gsattler | Multi-Way | 4 | 20th May 2002 05:54 PM |
| Page generated in 0.10334 seconds (79.31% PHP - 20.69% MySQL) with 10 queries |
