Old 7th March 2004, 10:26 PM   #1
Question bass guitar cabinet wiring
quick question
is there any way for me to wire 12 8ohm driver (all identical) together to end up with a 4ohm load?
for all of you wonder what this is for, i'm making a bass guitar cabinet with 12 8" drivers.
thanks
Old 7th March 2004, 10:42 PM   #2
Bill Fitzpatrick's Avatar
No, not if you want them all to play at the same volume.
Three paralleled groups of 4 in series would give you 10.6 ohms.
Four paralleled groups of 3 in series would give you 6 ohms.
Take your choice.
Old 7th March 2004, 10:59 PM   #3
dooper is offline dooper  Canada
Interesting idea. Can you share what drivers you're going to use? Cabinet volume? Sealed or vented?
TIA,
dooper
Old 8th March 2004, 01:15 PM   #4
You'd need to use only 8 drivers.
You could make a 4x8 cabinet - 8 ohm, and an 8x8 cabinet - 4 ohm.
This would give you a choice cab size vs venue.
Your amplifier might be able to handle both in parrellel, 2.7 ohm.
(which is of course is wiring option of your 12x8)
If so you would have a choice of three cabinet set ups.
For the 12 x 8 I'd wire it to be switchable between 2.7 & 6
ohms, though this isn't easy, you'd need a multipole switch.
sreten. (4x10 sealed, 1x15 reflex)
Bass Cabinet Speaker Wiring DAVID WARD Multi-Way 6 9th July 2009 11:15 PM
Beginner - Building a bass guitar cabinet richmoore1998 Multi-Way 3 27th December 2008 02:31 PM
bass guitar cabinet babagau Multi-Way 6 2nd September 2008 11:16 AM
Bass guitar cabinet at kappalite3015LF sokol Multi-Way 0 14th May 2007 07:19 PM
New Speakers for 2x15" bass guitar cabinet. Nate Groadie Multi-Way 0 20th May 2003 03:38 AM
Page generated in 0.07033 seconds (70.75% PHP - 29.25% MySQL) with 10 queries
