Old 7th March 2004, 09:56 PM   #1
B.VDBOS is offline B.VDBOS  New Zealand
B.VDBOS's Avatar
Default Inductor value?
Hi, I've just had a look at the pasive crossover for my 3 way speakers and I found an Iron core inductor for the woofer
I want to replace this with an air cor inductor to see if it makes an improvement, maby my bass will stop dissapearing at high volumes
Does anybody know a way of measuring an inductor to find its value? I dont know the crossover points of the speakers or any thing like that.
I have a multimeter and a p.c baced frequency generator if that helps?
Any advice would be a help
Billy.
Old 7th March 2004, 10:29 PM   #2
sobazz is offline sobazz  Denmark
sobazz's Avatar
You could use your computer - if you have a sound card capable of recording the same signal on line in as is played on line out without internal feedback. Speaker Workshop here enables you to measure passive components. Depending on the values of the components (the higher the values the greater the relative deviation) and how precise your calibration of the software is useable. Certainly good enough for crossover components, since the values typically are very low.
There are some PC based scopes. They might be able to do the same. I don't know.
Good hunt!
Old 7th March 2004, 10:34 PM   #3
Bill Fitzpatrick's Avatar
Plug the frequency generator into a pre-amp connected to a power amp.
Wire a film capacitor (about 5mfd, 5%) in series with the inductor and a 10 watt wirewound resistor (about 20 ohms or so). Connect this network across the amps speaker terminal.
Attach the multi-meter across the resistor. With the volume set fairly low, adjust the frequency of the generator so that the reading of the multimeter is maximum. This will find the LC resonant frequency.
Then:
L = ((159235/F)^2)/C
Where L is in microhenries, F is in KHz and C is in picofarads.
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
Inductor DCR ? mace Multi-Way 3 9th September 2007 10:41 PM
Inductor lot 875+ for the DIY RAW Multi-Way 1 14th August 2007 01:23 AM
air core inductor vs. iron core inductor WBS Planars & Exotics 5 7th May 2007 11:02 PM
WTB: INductor:0.2, 0.25, 0.33& 0.9, CAP: 2.7uF&8.2uF gengis Swap Meet 0 6th July 2006 08:46 PM
Page generated in 0.07363 seconds (72.47% PHP - 27.53% MySQL) with 10 queries
