I'll be attaching 4 - 12" woofers to a 3/4" MDF baffle. The mounting bolts will be located 1/4" from the edge of the hole (can't help the way the speaker is made).
I don't want the T-nuts to break out the edge close to the woofer hole, but at the same time I don't want the MDF to lose grip with the fastener in case I need to replace a driver. Which is a better fastener for my application, T-nuts or Propell-nuts, and why? http://www.stafast.com/products/tnuts.html |
#2 |
Do you smell smoke?
That close to the edge regular hex nuts would probably be best of you can get to them...
#3 |
Can you offer any pics or links as to what you're refering?
Also, I'd like to recess the bolts somehow so that I can veneer over them, if that is advisable. Since I probably won't be using a speaker grill (at least for now) I want the baffles to be free from sight any signs of bolts. |
| Page generated in 0.05934 seconds (72.57% PHP - 27.43% MySQL) with 9 queries |
