135Hz Segmented Horn Midbass Build
Old 28th July 2017, 05:28 PM   #81
pcgab is offline pcgab  United States
Those are looking pretty awesome!
Old 28th July 2017, 09:49 PM   #82
JShadzi is offline JShadzi  United States
JShadzi's Avatar
Thanks! I appreciate you following along!
Javad
Old 30th July 2017, 05:42 PM   #83
JShadzi's Avatar
You know in Goonies at the end when the pirate ship sails out and the cop says "holy Mary...Mother of God!"...?
Well that's sort of how firing these things up for the first time was like!
First some finishing details.
Rat Rod passive XO, low pass around 125hz
Mounting the drivers
Dual opposed configuration
XO installed and split to top section
Aaaand, wala
Did some quick XO tweaking and ended up with this, bass is about 3-5db down and I'm going to try Biamping to even that out before resorting to active.
Initial impressions...WOW, this is the type of speaker that gives you a physiological response to music, I find my heart rate and pulse raising listening to my reference music. Bass is prodigious, like shake your hair and other body parts powerful, SPL is effortless, I hit 50% volume on my Adcom preamp and it sounded like the house was rattling from the inside out, volumes easily 115db+ at 1-meter, and that's on less than 300 watts or so per channel (Adcom GFA-555).
Fun stuff! Will keep playing with them!
Thanks,
Javad
Old 31st July 2017, 06:50 AM   #84
manninen is offline manninen  Finland
manninen's Avatar
if you have all the active channels try to set it up as cardioid bass, that would be fun to hear
Old 31st July 2017, 09:07 PM   #85
JShadzi's Avatar
For now I'm staying passive for simplicity sake but yes, that would be fun to try on active, and I have everything to easily do it, will keep you posted!
Old 1st August 2017, 04:26 AM   #86
JShadzi's Avatar
I did some more XO tweaking and they are sounding very good, I also was able to bring the bass up to the level of the midbass horn.this is a blended sweep gated to 5ms
Close up on the bass FR, comparison with both ports open and one plugged, actually quite close to the models if you consider room resonances
I demoed them for some friends last night, Tricycle Film and the BB's track 1 almost resulted in a few cardiac arrests with the incredible dynamic range of that album =)
Javad
Old 5th August 2017, 11:23 PM   #87
JShadzi's Avatar
One last touch on these, I wanted to do some nice speaker wires that always stay with this set.
I started with 6 strands of 18g cooper wire. We were all out of unicorn dust silver wire at 034Motorsport so this had to do.
I twisted the 3 wires together as positives and negatives then twisted those together. The fun part was passing all that through some 1/2" clear shrink tuning, I should have used 3/4" but I wanted it to be tight.
Some ends have banana plugs and others have spade connections.
These are the main wires that go to the sub XO input
I cleared over the bodies to insulate them
Then the wires out of the XO into each sub and up to the midbass XO
And installed
Horn L pad finalized, this configuration allows quick and easy swapping out of resistors to adjust the L pad w/o any soldering.
Thanks!
Javad
Old 12th August 2017, 04:35 PM   #88
JShadzi's Avatar
Here's a video of them playing some Diana Krall, with detail shots as well
Seos24, 135HZ Horn and Quad 18" Subwoofers Diana Krall - YouTube
Old 12th August 2017, 04:53 PM   #89
JShadzi's Avatar
And a couple more pics
Old 14th August 2017, 07:28 AM   #90
hajj is offline hajj  Lebanon
hajj's Avatar
Biggest headphone set ever!!
These look seriously nice!
I'm sure you have probably mentioned this before, but what's the driver compliment?
Btw, twisting your cables this way might add some capacitance to the cables
Nick
135Hz Segmented Horn Midbass BuildHide this!Advertise here!
Material to build midbass horn Audiodidakt Multi-Way 34 8th July 2016 06:24 PM
Inlow 135hz mid bass horn? frangus Multi-Way 4 21st April 2016 02:39 AM
Midbass horn unaHm Multi-Way 649 9th December 2015 06:21 PM
Need help with a midbass horn ndcraig PA Systems 24 26th September 2013 03:29 AM
Midbass J horn tade Multi-Way 26 19th November 2007 01:33 AM
