Old 7th March 2004, 06:33 AM   #1
frugal-phile(tm)
planet10's Avatar
Default Sanity check
The ApexJr Super 8 has BL measured as 2.287 lb/A.
To use Martin's model i need BL in N/A
with 1 lb-ft = 1.356 Nm and 1m = 3.281 ft i'm figuring
1 ft/A = 4.45 N/A
ie this driver has a BL of 10.175 N/A ??
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th March 2004, 06:41 AM   #2
Got a link so I can look up the Thiele-Small parameters on that?
BoxModel will straighten this out.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 7th March 2004, 06:59 AM   #3
Here are your Thiele-Small parameters via BoxModel.
Bl is 9.18 Tm which I believe is the same as NA.
The numbers in the dark blue I wrote in, (I estimated 200 sq cm for the Sd), and the numbers in the light green underneath BoxModel calculates.
Neat, huh?
-Anonymous
Old 7th March 2004, 08:03 AM   #4
frugal-phile(tm)
planet10's Avatar
Here are the measured parameters picked out of the pdf at ApexJr
dave
Old 7th March 2004, 10:31 AM   #5
Default Re: Sanity check
1 ft/A = 4.45 N/A
dave
Should be just a case of converting pounds to newtons,
(1kg = 2.2 lbs = 9.8 newtons)
2.287 lb/A = 1.04 kg/A = 10.2 N/A.
sreten.
Old 7th March 2004, 06:04 PM   #6
frugal-phile(tm)
planet10's Avatar
Thanx Sreten... i've long lost handy access to all those convrsions in my head, and the others were the only quick factors i can find... now that i see 1 kg=9.8 N it all comes back... thanx for the forhead slapping moment
dave
Old 7th March 2004, 06:59 PM   #7
You still got the right answer, near enough, sreten.
Old 7th March 2004, 07:32 PM   #8
joensd is offline joensd  Germany
Here´s a handy tool for converting quite a few units which I recently found on the net :
Old 7th March 2004, 08:08 PM   #9
fireman is offline fireman  Canada
fireman's Avatar
Hey Dave, what are you up to with this woofer ?
I meant to build something with this baby a few months ago. Time and money had me put the project to rest for a while. If I get the promotion I applied for, I guess it'll will have to wait 'til I move to my new workplace. Hopefully, I'll then have a real workshop where I can work on my speaker projects.
Old 7th March 2004, 08:13 PM   #10
frugal-phile(tm)
planet10's Avatar
Useful if you are running Windows....
I downloaded an OS X ap called Balance Pro... but didn't find the lbs > Netwtons conversion till just looking now.
http://www.MacDev.ca/
dave
F1 Voltage sanity check rpafenberg Pass Labs 7 28th March 2009 10:42 AM
Sanity Check ..... please Lostcause Digital Source 0 16th October 2008 06:19 PM
LX-72A Sanity Check for Noooobie? Vespasian Tubes / Valves 5 24th October 2006 01:20 AM
This model can't be right... need sanity check NogginBoink Subwoofers 4 30th July 2005 09:14 PM
Subwoofer sanity check fat_terry Subwoofers 5 4th September 2004 10:49 PM
Page generated in 0.11984 seconds (79.73% PHP - 20.27% MySQL) with 11 queries
