I need a little help. Have two pairs of loudspeakers needing drivers.
Wharefedal Denton lls, .3984 ft^3, sealed, 8" driver xover: tweets: .8mH, 16mfd, 50V woofer: 2.0 mH, 50mfd, 50V np and Musical Fidelity MC-2: no xover info .68 ft^3, heavily stuffed, 2"X6" port TDL tweeter and woofer any ideas? |
#2 |
I have a pair of the rather excellent MC2's.
Have all the drivers gone west ? TBH trying to reuse crossovers is not the way of going about it if all the drivers are not working. The Denton's combination of size and and an 8" bass driver is going to make life difficult. If all drivers are gone give up on the crossover. fit an additional front baffle and build a 6.5"/1" two way - with offset drivers, suggest using Dayton drivers - for more info : http://www.speakerbuilder.net/web_fi.../D2/d2main.htm Any changes because of the Denton cabinets can be sorted out here. The MC2's - more details of what doesn't work please. The tweeter is a TDL / Monitor Audio unit, the bass/mid unit is an Audax TPX unit, similar to or the same as: http://www.blackdahlia.com/the_dahli...ker_system.htm Incidently the tweeter was designed to be a drop in replacement (with minor sensitivity padding) for the near ubiquitous Audax rectangular dome tweeter. |
#3 | |
If it sounds good... it is good! |
#4 |
The tweetes in the Dentons are paper, I'd like to use domes. I have 2 prs of tweeters kickin around, a pair of rectangular tweeters out of a pair of Missions, and a pair of circular ones. One woofer is smoked. I destroyed it postmortem to have a look. I had thought of just starting fresh with a new xover, and creating a stepped baffle for the front and using a smaller driver.The volume is only .4 ft^3
The MC-2s require 1 woofer. They were given to me sans woofer. The previous owner gave up trying to find a decent replacement. They sure look like TDL drivers (actually I know they are as I had called musical fidelity who verified that they were, but alas provided no further info). thanx for any and all ideas |
#5 | ||
paragraph 2 - I know my onions. I own the Loudspeakers. The reason the MC2 is so heavily damped is the TPX drivers delivered had different parameters, compared to the original parameters claimed. (A phone call, yes well, they are bound to know, not) Quote:
http://www.blackdahlia.com/articles/dahlia_debra.htm Unfortunately it deals with new tweeters not new bass units. |
#6 |
not trying to flog a dead dog here.:-(
the fitted woofers are paper w/rubber surrounds. Production dated are July 1987 thanx for all your help thus far. Do you think that it's worth resurecting these ? |
#7 | |
My best guess : http://www.partsexpress.com/pe/pshow...number=290-063 |
#8 |
I took out the one remaining woofer in the Mc-2s. no markings. appears to be poly.
#9 | |
22PPGHN8 ohm. Here is the UK I'd simply buy two Audax 8"s available here at very reasonable prices from Maplins and play with the c/o. |
#10 |
Hi again,
I've been digging a bit more and the MC2 bass unit is not the same as the Audax units in the Black Dahlia, though those units do resemble the clear phase plugged TPX driver used in the MC4's. I seem to remember at the time that the MC2 was touted as using a budget version of the MC4's driver and that it used a TPX cone, its impossible to tell by inspection. Without ripping all the foam out I remember it being 2nd order LC for the woofer and RCLC 3rd order with an attenuating resistor for the tweeter. I seem to remember the resistor being before the c/o components for the tweeter. So one possible way forward - remove the woofer components and the resistor - wire a link across the resistor and inductor points. As the speakers are biwirable you can now play with these outside the speaker. The question is - what pair of bass units to try ? (0.7 cuft = 18litres) The P22 here is a possibility : http://www.apexjr.com/speakerstuff.html IMO they are worth the saving attempt. The tweeter is still pretty good and was one of the earliest to have a damped rear cavity. The cabinet construction is seriously braced and as you know stuffed to the gills with high grade foam. |
| Found retro 80s amp - Anyone know what this is? | tiffin4tea | Chip Amps | 7 | 15th February 2009 02:16 AM |
| not sure where this fits but it's about a PSU | jarthel | Power Supplies | 1 | 17th August 2006 03:57 AM |
| retro marantz | karma | Solid State | 25 | 6th June 2004 06:05 PM |
| Page generated in 0.13286 seconds (81.40% PHP - 18.60% MySQL) with 11 queries |
