Old 6th March 2004, 12:12 AM   #1
Default Crossover design mojo...phase alignment with a hint of zobel?
OK.... I may be way off base here, but I've been doing some thinking(I know..... it's a dangerous thing for a DIY person{grinning}). After reading up on passive crossovers, I found(or remembered) that a first order passive xover would put the driver 90 degrees "out" of phase. Now could I use this to my advantage in designing my next SQ car audio system? I plan on having the tweeters on the dash(practically vertical, facing the driver's and passenger's seats,so none of my "phase alignment" would be needed). The mids and the mid bass on the other hand will be in the door("rotated" 90 degrees from the plane of the tweets). I will be using an active crossover with "poly-amplification", however the mid needs a higher low pass point(800hz) than my active xover provides(500hz), so I thought I could use a first order passive xover(just a cap) to get my xover frequency right *and* "align" the phase!?! The mid bass would be manipulated in the same way.
Well if all of this isnt enough, I would like to use zobel networks for all the front drivers as well. I have found some online calculators, that use the nom imp and a value that I don't know how to get....."the frequency at which the nom imp is doubled". Anyone know how to get this or more appropriately a better way to design a zobel network for speakers without having T/S parameters(unless some kind soul knows the TS for Infinity's EMIT tweets(out of the RS4 home speaker I believe) and their RSDS 5" dome mids(the car audio ones), I'm still undecided on the midbass)?
Thanks......
Nathan
zobel / phase PeteMcK Multi-Way 13 10th December 2008 11:53 PM
Needed: 2 way, phase linear crossover design references J.R.Freeman Multi-Way 6 15th September 2008 03:10 AM
Wandering phase plugs? helpful hint. OzMikeH Full Range 5 11th March 2008 09:45 PM
Phase alignment of the isobaric design Jimmy DIY Multi-Way 14 1st April 2006 03:42 PM
How can a zobel add an order to the slope of a crossover? Bricolo Multi-Way 1 27th June 2003 12:55 AM
Page generated in 0.06574 seconds (68.18% PHP - 31.82% MySQL) with 10 queries
