sure, Im very curious to hear your big line array. if they beat everything ive heard, ill also build mine. but Im very reserved concerning EQ/DSP. I do hear serious degradation when the signal is not bitperfect and I use digital VC/DSP/ digital EQ.at least, come here to pass the midrange's blind test
we need participants
I'm bringing back to life that thread because i'm about to make it.
It's gonna be even ''worse'' than what i thought, since we failed every 3 blind tests we made so far, including the one from today (digital to analog converters)...
So basically, i'll use that:
A) Bower & Wilkins CM9 on a A14 integrated preamp/amp/DAC
against:
B) DIY fullrange FR151 on a miniDSP 2x4HD and ICEpower amp, EQ cloning the B&W response.
SPL-matched. Same few music files, from a common source (Mac Mini).
I will not even bother to put them in different rooms, they're gonna sit side by side so we should be able to spot something, spatialisation-wise... In fact, WE SHOULD hear a day & night kind of difference, am i right?
Well, i'm not sure myself, haha... i sure don't expect 100% positive results from every ears.... but let's try it anyway.
against:
