Building a reference active 3-way speaker for high SPL
Old 5th March 2004, 05:21 PM   #1
Ricren is offline Ricren
Ricren's Avatar
Default Building a reference active 3-way speaker for high SPL
Hi folks,
I need a piece of advice with this:
Iíd like to build a high quality 3-way speaker for monitoring purposes that can output high sound pressure. (110 db).
Recently Iíve been modifying an old Urei speaker with the addition of a digital crossover and tri-amplification. The experiment went so well that Iím thinking, that perhaps to build a 3-way monitor speaker is not an impossible thing after all. I do not have the knowledge to choose the drivers and design the box, however. I have a few measurement devices and tools that can help. Iím not great building enclosures, but I can try.
So if anybody can help with comments or advice would be great.
The speaker class that Iím approaching is like this Dynaudio baby:
http://www.dynaudioacoustics.com/Def...846&AjrNws=603
A tri-way active monster with crossover points at 300 and 2500 Hz and 1200W of power plus extensive DSP. I think I could handle the electronic part of the project, but for the speaker enclosure and drivers I do not have a clue!
So let me introduce a few reliminary questions:
1-How do you like the proposed design to ďcloneĒ (Dynaudio AIR 25 speaker) Any possible flaws or improvement?
2-Can you recommend any drivers? Pity that Dynaudio do not sell the raw drivers anymore. Iíve heard that Vifa or Skan Speak are great, too.
3-Do you remember any related DIY project that could be used as a reference? Not need to re-invent the wheel, right?
Thanks for your time, any advice would be greatly appreciated.
Ric
Old 5th March 2004, 07:29 PM   #2
Nappylady is offline Nappylady  United States
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
If you're going for SPL, then you should look at JBL's offerings.
My ideal active monitors would be 2-way, with a 15" 2226 on the bottom (or 6 ) and one of their horns on top. Sealed, vented, not sure.... nice chipamps inside to power the thing.... heh, this could be fun!
Actually, perhaps a better woofer choice would be the 15"er that's at partsexpress right now... the limited run one... it's like $80 less and has higher total displacement.
I really don't think 3-way is necessary if you use a good horn that can get down to 1000hz, but *shrug* some people get bent out of shape about directionality and such.
I'm not an expert in either area but... this sure sounds like a fun project! I'm going to pay attention...
Old 5th March 2004, 08:48 PM   #3
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Default Re: Building a reference active 3-way speaker for high SPL
There's a project that is close to what you are describing, a passive WMTMW design called the PX with supposed superb clarity at high SPL, that Wayne J at speakerbuilder.net will publish soon. The DIY version uses a Vifa ringradiator, Audax mid, and Usher woofer to get the budget to $1K. The commercial version uses Scan Speak ringradiator & woofer plus the Audax mid IIRC, but the design of that one won't be published of course.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 5th March 2004, 09:35 PM   #4
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
http://www.griffinspeaker.com/
http://member.newsguy.com/~stigerik/html/audio.htm
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 6th March 2004, 04:15 AM   #5
Ricren's Avatar
Default I konw that sub!
Tks for the link. Interesting. It was a surprise to realize that they are using the same driver that I used for my subwoofer. Nice driver. Not cheap.
"The 460 mm (18 in) long-throw paper pulp coned woofer comes from RCF in Italy, a company owned by Mackie. The driver is chosen for its extremely high output capability, low distortion and suitable Thiele-Small parameters."
So basically they use a D'apolitto MTMW config with crosover freq points at 130 and 1700 Hz. The woofer is almost used as a subwoofer. They even sell another model without this "sub-woofer".
I heard about Seas driver but that tweeter brand (stage acompany) is new for me. I'll serch for pricing on those units.
cheers
Ric
Old 6th March 2004, 04:26 AM   #6
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Stage Accompany are planar tweeters that handle lots of power, are efficient, and are reputed to sound very very good!
They are used in PA sound systems as well as monitors.
I've heard it's best not to use the horn option
Price? around $600 US each! There had to be one bad point!!
I think they would fit your plans very well
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 6th March 2004, 05:23 AM   #7
Ricren's Avatar
Aja! That will be 3K in tweeters for a 5.1 system. I think I can live with that (barely...). Besides a web search indicates that everybody have a good opinion on this tweeter, plus it can be crossed fairly low (1700-2000 Hz). I remember seeing something similarly shaped on the ADAM monitors. And people really like those boxes.
I do not have prices for the Seas drivers. I'll keep searching.
Ric
Old 6th March 2004, 07:06 AM   #8
diyAudio Editor
Variac's Avatar
The Seas drivers are listed at $162 ea at Madisound.com
Old 6th March 2004, 08:27 AM   #9
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
A 3-way built around an Audax PR17 (or the PHL spawn) would give you a lot more efficiency than anything mentione so far, and they are no slouch in the Sonics dept.
An active system with the digutal XO really gives you flexibilty wrt drivers... the Stage Accompany is a beauty. AFAIK a spin off is Alcons. But any number of nice high efficiency horn tweetrs exist... thn bass to match. A set of Llambda 15s would be my pick.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 6th March 2004, 03:14 PM   #10
Ricren's Avatar
Default horns are nice. Changes are nice too.
Originally posted by Nappylady
My ideal active monitors would be 2-way, with a 15" 2226 on the bottom (or 6 ) and one of their horns on top. I really don't think 3-way is necessary if you use a good horn that can get down to 1000hz
I understand what you mean. Apparently, for efficiency nothing beats a horn. However I already have a pair or monitors with horns on them and I've been using this setup for such a long time, that I feel it's time to try something different.
Ric
Building a reference active 3-way speaker for high SPLHide this!Advertise here!
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
Anybody out there replacing high-end speaker's passive crossovers with active ones? wigginjs Multi-Way 13 13th May 2005 01:55 PM
Designing a Reference Speakers - 4 Way Active HiFiNutNut Multi-Way 11 6th June 2004 05:01 AM
3 or 4-way active High End speaker ??? Jan Dupont Multi-Way 70 29th May 2004 05:28 AM
Building a high output speaker Solinar Multi-Way 7 13th May 2004 05:36 PM
Copyright ©1999-2017 diyAudio
