wait few days, i'll test the RS225 next...
http://www.diyaudio.com/forums/mult...midrange-blind-testing-need-your-help-95.html
might surprisingly do well 2-way, who knows
I'm thinking a tall WWMTMWW around 125 L tuned to 30hz......just not sure on the MTM part.......
Depends what you'd like to accomplish with this project. Sound wise it'd
be better to use one midrange dome(cone) and one tweeter dome for better
vertical off-axis response. 4 of RS 225-4 in one cabinet are good for
89 dB/2,83V/1m, baffle step loss calculated in.
Reduced vertical dispersion is preferred....less ceiling/floor interactions. The MTM/ Ribbon config assures this. I'll be sitting on axis for critical listening with a system of this magnitude for sure.
Unibox sims and an 11" baffle give me 92 db 1w1m ?
My mistake, I should have said about 91-92 dB at 2,83V/1m
for 4 units series/parallel with baffles step loss, not 89 dB.
Your data seems ok, 2 pi.
If you want a lot of really nice bass, use all 8, I've build speakers with 2 in each tower and the bass was really good, made me want to add 2 more per side to the mix. I love the bass quality and amount this woofer produces.
Javad
The thought would be four per side for a total of eight. The extreme bottom would be handled by a pair of sealed 18's with LT function via DSP
I would build a pair of the Endeavour Audio flagship speakers.
E-5 Speaker System
They use a HiVi 6" and Scan Speak Be tweeter and sound fantastic!
E-5 Speaker System
Maybe OEM RAAL and two Scanspeak 10F's?
I'd make an MTM with the Daytons and a compression driver on a waveguide and sell the four remaining woofers.
E-5 Speaker System
The smaller ones by them sound really good too.
- What would you do with 8 Dayton RS225-4's
