I am building this two way speaker. To get more bass from the system, I wanted to learn about passive radiators and maze speaker...
Here is what I am building:
Illuminator-Monitor
I want to use a passive radiator to get more bass from the speaker. I don't know how to calculate this, so I wanted to ask you... How big should the passive radiator be? 10" will be enough?
There is also another idea I am thinking of. Why do people do maze speakers? On this example, they guy has used a full range speaker and to have stronger bass, he has used a maze... Is this an option for me too to get stronger bass from my speaker? And how can I calculate...
Thank you very much...
Illuminator-Monitor
A PR won't give you more bass then a vented cab, it just make the bass looser.
Fixed it for ya.
You size PRs at twice the area of your woofer. A PR won't give you more bass then a vented cab, it just make the bass tighter. The maze is a back horn. It macanically amplifis the bass. If your woofer is 10" then use 2 10" PRs.
Thank you, so you say that, IF I use a PR, I should double the woofer's area...
I agree that a horn does not need a passive radiator.
Passive radiators are generally used when a very long port is required and may not be practical. As for what size and mass are required, that's determined through modelling.
Thank you, the picture of the maze is not mine, I just asked what it does and got my reply
What I wanted to do is to get more bass from my speakers I built here:
Illuminator Monitor - Jantzen-audio.com
So guys I think you are all saying, I don't need a maze (back horn) or a passive radiator for this design... Right ??? I feel like I already don't need, just asking if they will make the speaker better... :roll eyes: :roll eyes:
Time to build a subwoofer that doubles as a stand.
Oh, do you mean I need one ? :roll eyes:
Are you suggesting an active subwoofer? I have slowly started to feel that I am going to need one...
If you want more bass from the design, then build the floorstander version. Details are in the link you provided.
Ralf
Thank you, I will do that version...
- Passive Radiator for 2 way speaker
