Hello everyone... Can anyone tell me if the Alpha 15A is viable to be used in a Ripole design? Also, I have seen the Ripole to be in a box or cube configuration...what would happen if the back of the Ripole is extended to a rectangle? All ncomments and opinions are welcome...
I think to build a Ripole it is better to take drivers with qts 0,5 to 0,7. In the Ripole qts will rise by fs is going down. When you will build it with a driver with qts >1 the impulse response get worse. Then better build the Linkwitz design with bigger openings...
The Alpha 15a is a good budget-choice for i-frame or big sealed design.
