My speaker has an 8" beyma mid and Vifa BC25SC06-04 1" horn loaded tweeter. The tweeter sounds good in general, but gets a bit sharp and sad when playing very loud.
This speaker had a peerless horn loaded 1" tweeter previously and it worked better. I think that had 98-99dB (8 ohm).
Are there any good hi-fi horn loaded tweeters with >95dB efficiency around?
I am not looking to go in to compression drivers and so on.
Selenium used to make a couple of slot loaded tweeters which were inexpensive, and very nice sounding with a ring-phenolic diaphragm - moreso to my hearing than things like Polydax and Audax titanium diaphragm bullet tweeters. I don't know why they were discontinued. The ST324 was only around $25 US
http://www.parts-express.com/peerle...shielded-dual-ring-radiator-tweeter--264-1012
You could try the above mentioned Vifa dual magnet ring radiator or one of the various SB Acoustic neo tweeters in a waveguide.
The only negative I see is the high cutoff for matching to an 8" mid.This Peerless horn tweeter has 97dB.
Peerless by Tymphany XT25BG60-04 1" Shielded Dual Ring Radiator Tweeter
Yes, by using 4 Ω units you gain 3 dB compared to 8 Ω units.
Compression drivers and whatnot aren't a bad way to go- do keep your options open. Impressive new compression driver from Peerless - Techtalk Speaker Building, Audio, Video Discussion Forum <$50 per maybe $60 with good quality but not outrageous crossover parts per side and 98 from 1300-16k.
- High efficiency tweeter
