Old 3rd March 2004, 01:01 AM   #1
JeremyD is offline JeremyD  United States
Default Help with horn...
I'm trying to model up a conical, rear loaded horn for a tangband w4-616s driver. No matter how I do it, I just cant get the response to smoothen out. I've tried everything. I know the driver is not ideal for horn performance, but it should be giving me better results than I'm seeing. Perhaps I'm over looking something.
Take a look....
Old 3rd March 2004, 03:19 AM   #2
Default Input Parameter Error !
Some of the entered parameters are incorrect. First, I get Cms as 1.23E-03 (note you have +03 BIG difference). Also I have RMS as 0.66 (not .01). I also have Mmd as 3.96, but your value of 4 should be close enough anyway.
Try it again with these figures
Cheers
Old 3rd March 2004, 09:40 PM   #3
The cms was entered using the spec sheet directly from tb.....
http://www.partsexpress.com/pdf/264-818.pdf
cms is listed as 1347 NM-1
When trying to calculate RMS (this spec was not listed), the program spit out a number less than 0, hence the null value there.
Old 3rd March 2004, 09:46 PM   #4
Even making those changes yeilds no change in the response of the horn unfortunately
Old 3rd March 2004, 11:35 PM   #5
GM is offline GM  United States
GM's Avatar
I don't use Hornresp and from the screen shots I can't tell what Fl/FH you want. BTW, I assume this is a backhorn, so you won't get a very smooth sim or much gain unless the horn is very long, with a slow ~conical expansion, terminating in a very large mouth.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th March 2004, 05:15 PM   #6
Any other thoughts?
Old 7th March 2004, 05:28 PM   #7
AR is offline AR
I am not an expert, but....
Generally, increasing horn mouth size decreases the magnitude of the peaks and dips.
Old 7th March 2004, 07:38 PM   #8
REDSKIN is offline REDSKIN  England
I'm not an expert but here's my 2 cents...........
In Hornresponse help it says to set vrc/lrc to zero when modeling backloaded horns.
After playing with vtc, s1, s2.......etc I managed to get rid of some of the peaks and dips. Prehaps you need to play around a bit more with the variables.
Your not givings us much help as to your horn expectations. What are your fl/fh goals.
Why the short horn length? to go lower requires a longer horn.
Try s1=30 s2=40 s3=250 s4=600 vtc=400 atc=60 to give you a flatter start.
Don't know if any of this helps.
He shoots. He scores!
Horn experts - Please help to determine optimal throat size for low-mid horn pk Multi-Way 7 21st March 2010 05:31 PM
Single Driver Horn Base Port from Frugal Horn EmergencyDpt Swap Meet 0 26th October 2008 01:24 AM
RCA MI-1425 with MI-1469 Horn, MI-1457 (W-horn) with RCA MI-? fieldcoil woofer thekop-bkk Swap Meet 0 26th September 2008 03:55 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
Page generated in 0.09384 seconds (78.58% PHP - 21.42% MySQL) with 10 queries
