Old 3rd March 2004, 12:05 AM   #1
dmcleod is offline dmcleod  United States
Question Need t/s parameters for RS 40-1033 (6.5" woofer)
Hello,
I'm looking into making some 2-way towers using a couple of Radio Shack 6.5 in. woofers I picked up 2 years back. I need to get the Thiele-Small Parameters to determine box dimensions and design. If anyone has the t/s info or has any experience using these drivers in an enclosure your help would be greatly appreciated.
The drivers are Radio Shack 40-1033 and basic stats are here:
http://support.tandy.com/support_audio/doc58/58248.htm
Cheers
Old 21st June 2004, 06:03 PM   #2
DavidLD is offline DavidLD  United States
Default What I know is here
http://members.aol.com/Debertin/spbuild.htm
Old 21st June 2004, 09:05 PM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
It is not difficult to measure the parameters yourself.
The classic way to do it:
http://www.epanorama.net/documents/a...arameters.html
Another way:
http://sound.westhost.com/tsp.htm
You do not need a signal generator or a frequency counter because you can download a program that serves as a substitute as long as you have a soundcard - I just use the headphone out of my powered speakers and a little jig I built:
http://www.nch.com.au/tonegen/
All you need is a 10 ohm 1% resistor and a Multimeter and some hookup wire...
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 24th June 2004, 03:08 AM   #4
Thanks everyone for the information. I've got the box together already and am in the middle of the painting process. MDF is a real pain to paint with spray paint so it's slow going at the moment. Once I get the drivers in and give it a test run I will post some final pictures and measurements. In the mean time here are some shots of the cabinets before they started getting blasted with enamel.
Cheers
2 Way Speaker Project
Parameters for TacT woofer cph2000 Multi-Way 3 24th April 2007 12:08 PM
T/S parameters of philips 8'' woofer hydrovac Multi-Way 4 21st August 2005 05:31 PM
need the Thiele/Small parameters for Jamo woofer 22392 Ralphies Multi-Way 0 12th April 2005 10:58 PM
DVC Woofer- Does series vs parallel alter T/S parameters? treedog Subwoofers 11 14th January 2005 01:10 AM
how do i find thiel small parameters for the radio shack 40-1035 15" woofer zuki Multi-Way 7 18th February 2004 12:55 PM
Page generated in 0.07478 seconds (70.59% PHP - 29.41% MySQL) with 10 queries
