Watts = Quality
Watts = Quality
Old 4th May 2004, 06:39 AM   #71
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
dave, just when i was hoping to build a parallel push pull sing El84s you suggest that one should not use multiple tubes atleast not more than 2 (PP).
...still looking for the holy grail.
Old 4th May 2004, 07:13 AM   #72
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Watts = Quality
Sorry... but no 2 devices are ever quite the same, so when paralleled you get their average. But everything is a tradeoff -- if you need more power maybe a meatier tube (ie EL34)?
That said, i've heard some amps with paralleled output devices, one just wonders how the same amp would sound with half the tubes.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th May 2004, 02:30 PM   #73
amo is offline amo  United States
Default its all how you look at it........
High efficiency is great, but it is usually required when something else is a hog. The example in the first post refers to an 8 watt amp. What is the efficiency of that thing? So high efficiency speakers are required because we want Class A, with little heat, and a small electric bill....... A great man once said "All things are relative", or wait, was it "All things are invarient"???????????
Old 4th May 2004, 08:20 PM   #74
b-square is offline b-square  United States
b-square's Avatar
Originally posted by planet10
If that comment is aimed at the comment in my post -- i don't consider that a generalization, but a fact of life.
dave
The "problems" with sound quality are entirely in the ear of the beholder. It might be more difficult or more expensive to build an amp of a given "quality" with higher power output, but that is not quite the same thing.
How does the Aleph-X fit into your model?
Old 4th May 2004, 08:33 PM   #75
frugal-phile(tm)
planet10's Avatar
Watts = Quality
The one that Nelson is building for First-Watt may well be the best sounding one (20W -- so it will likely be a pair of devices in full Class A differential -- a subspace of PP)
dave
Old 4th May 2004, 08:55 PM   #76
markp is offline markp  United States
If you see an acronym other than RMS power, walk away from the product. The maker obviously has no scruples and would sell dehydrated water to his own mother.
If it sounds good... it is good!
Old 5th May 2004, 05:48 AM   #77
navin's Avatar
That said, i've heard some amps with paralleled output devices, one just wonders how the same amp would sound with half the tubes.dave
1. I did consider 2 x EL34 instead of 4 x EL84 but i was told that 4x EL84 sounds better.
2. i figured to control biasing using a SS biasing ckt so that all 4 tubes are biased to the same degree
Old 5th May 2004, 01:45 PM   #78
I've found that 4 x EL84s have just slightly more detail but 2 x EL34s have better bass response. You must bias individually to do it right in a multi pair PP.
Old 6th May 2004, 05:12 AM   #79
navin's Avatar
my el84 amp will be used above 300hz or so. my plan is to have a bi amp system running about 300-400hz (near BSC) and use the gain of the amp tom compensate for baffle step. the bass amp will be a SS. See the India Group Amp Project on this forum for details on that. the 2 amps will then feed 2 wide range drivers (jordan 125/53 or Fostex 165/83 or such) via a PLLXO.
so far the only part i have nailed down is the amps (EL84 PPP + Group amp). I still have to nail down the drivers, box size, etc...
the object of this speaker is that is must compete with the life style offerings from B&W, KEF, Dali etc...so the box cant be very large....if there is a box that is :-)
Watts = QualityHide this!Advertise here!
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 01:02 AM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 02:08 PM
Audiophile quality PA at below cost 18" woofer 1500 Watts of AMPS LuminousMaximus Vendor's Bazaar 1 1st April 2009 12:17 AM
watts vs watts Hayden Parts 7 30th July 2006 01:57 AM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 07:25 AM
