Old 2nd March 2004, 02:40 AM   #1
Default Mb Quart MCD25
I've seen this tweeter around and especially on ebay. Does anyone know of this tweeter, it's specs and how it performs? All reviews are welcomed
Jus run da trak
Old 2nd March 2004, 07:19 PM   #2
Joso is offline Joso  Germany
Hello,
MCD 25 is a Titan tweeter from MB Quart Germany.
QMS 3,45
Qes 2,85
Qts 1,56
Xmax 0,9mm
Sd 4,9 qcm
Re 7,1Ohm
LE 0,04mH
Fms 930 HZ
92db 2,83Volt
Max 100 Watt
8 Ohm
480Gramm
Voice Coil 25mm
3mm high
Greetings from Germany
Jochen Sonnenschein
Old 2nd March 2004, 08:56 PM   #3
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Default Rather Excellent Tweeter
Hello,
I plan to make a new crossover for an MB Quart driver compliment. It belonged to an MB Quart speaker (2X6.5'' + MCD 25). The cabinet has already been made again DIY (the same size), but with very steardy construction and excellent looks. The main reason we wanted to remake the speaker was the tweeter. It sounds excellent. If my memory serves me right must have seen it on Aerial Acoustics flagship 8 years ago. Maybe modified though. Well worth purchasing. For how much is it offered?
Old 2nd March 2004, 09:29 PM   #4
5th element's Avatar
Yes those specs do looks rather nice. Nothing bad to say about them, its got a very nice xmax, although its fs isnt remarkable if suppressed this tweet could probably handle its fair share of low xovers.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack!
Old 2nd March 2004, 09:51 PM   #5
The double magnet version was added to the MB product line, after testing the custom version they were building for Avalon Acoustics.
They are very good tweeters.
Old 2nd March 2004, 10:10 PM   #6
Wombat is offline Wombat  Germany
Wombat's Avatar
I used this one years ago. These MB-Quart parts have a nice built quality. I still use the 50mm Supronyl version in my speakers at home.
I found an old book with data about it:
If time permits - stuff some parsley in your ears and listen how it grows!
Old 3rd March 2004, 12:27 AM   #7
I guess i should of also told you'll i want to run it for highs in my car . Im guessing it should work the same way. what you'll think? If it isnt good, i saw the Morel MDT-20 and would buy that instead. But is that morel tweeter worth the $53 ?
Jus run da trak
Old 3rd March 2004, 09:46 AM   #8
Just note that the Qts of 1.56 tells me you have to careful and
take this into account when designing the crossover.
There is also likely to be a high impedance peak at resonance.
However if you pad it down for level matching using a series /
parallel resistor combination the parallel resistance will suppress
the impedance peak.
But not the frequency response peak due to Qts.
sreten.
Old 4th March 2004, 12:37 AM   #9
So can it work in my app.?
Jus run da trak
Old 6th March 2004, 03:12 PM   #10
Sorry i took so long to reply but, it's $20 a piece on ebay
Jus run da trak
MB Quart tweeters Coenlaf Multi-Way 25 18th January 2011 04:36 AM
Help with MB Quart Speakers stax Multi-Way 4 30th November 2007 02:21 PM
FS: Scan-Speak 25W/8562 woofers/MB Quart MBM 50 S Mid-Range/MB Quart MCD 19E Tweeters Ballylongford Swap Meet 0 1st August 2006 06:20 AM
MB Quart Slinkylink Multi-Way 1 14th September 2005 12:56 AM
mb quart qsd216 tenderland Car Audio 4 31st July 2004 11:31 AM
Page generated in 0.09720 seconds (78.33% PHP - 21.67% MySQL) with 11 queries
