#11 | |
#12 | ||
http://www.euphase.com/RawDrivers/8945-W.asp Quote:
The EBS is something that I hadn't considered, and something I want to try to learn more about. Now that I'm reading a little bit on it, it does look similar to what my modeling had resulted in. Between baffle step and EBS, that 2nd woofer's role seems like it could integrate nicely, but it also seems that I either need to find the proper volume that D'Appolito used, or I need to find a way to model this 2.5 way configuration more accurately. |
#13 |
Some curves :
for the final plot I changed Qts to 0.36 to crudely model some series resistance in the crossover affecting Q. |
#14 |
wow, that's interresting what a little higher qts will do.
#15 | |
way and a 2 way speaker with parallel twin bass units. |
#16 | |
Indicates a 0.8 DCR of the inductors will change Q to 0.36. It will also slightly change the sensitivity which is not modelled by changing Q, by around -1dB. Not that I'm saying Q=0.36 is the best value, I'll play with it. edit : shows Q stepped from 0.32 in 0.2 steps, Q=0.4 = 2R/driver, 2 drivers, left scale = 20Hz. |
| PC doesn't boot | Devil_H@ck | Everything Else | 41 | 8th June 2005 08:41 PM |
| Speaker size v Room size | cliffy | Multi-Way | 6 | 19th February 2005 08:34 AM |
| To Match Impedance on DI Box, or Not to match? | MisterAlex | Instruments and Amps | 1 | 21st November 2004 10:09 AM |
| Amp doesn't like computer :/ | Bryanm | Solid State | 1 | 18th June 2003 10:02 PM |
| Page generated in 0.08908 seconds (77.01% PHP - 22.99% MySQL) with 11 queries |
