Low pass filter 10mH & 100uF what the freq cutoff Low pass filter 10mH & 100uF what the freq cutoff - diyAudio
Old 20th June 2016, 11:59 PM   #1
supernut is offline supernut  Thailand
Default Low pass filter 10mH & 100uF what the freq cutoff
If I put 10mH 15AWG on + line of speaker and put 100uF capacitor between + and - lines
How much the frequency cutoff I will get
I plan to use in my 10" subwoofer to have frequency cut off about 250 Hz below
2nd order is just fine.
Can anyone provide the calculator of L & C for low pass filter?
Thank you.
Old 21st June 2016, 12:27 AM   #2
rayma is offline rayma  United States
Originally Posted by supernut View Post
If I put 10mH 15AWG on + line of speaker and put 100uF capacitor.
f = 1 / (2Pi SQRT(LC))
f = 1 / (2Pi SQRT(0.010H x 0.000100F)) = 159 Hz
Here's a calculator. http://sim.okawa-denshi.jp/en/RLClowkeisan.htm
Old 21st June 2016, 01:19 AM   #3
bwaslo is offline bwaslo  United States
bwaslo's Avatar
Or you can quickly model it with XSim (see my signature). The actual curve will depend on the impedance of the woofer.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 21st June 2016, 03:44 AM   #4
Thank you so much for Xsim
Mr. Bwaslo
Old 21st June 2016, 04:16 AM   #5
SEAS-3-Way-Classic-mkII
Anyone knows the value of parts of this crossover. Thank you.
Old 21st June 2016, 04:45 AM   #6
I try to calculate my Seas P25REX crossover but got wrong result.
Anyone help me
Old 21st June 2016, 06:37 AM   #7
bwaslo's Avatar
The trace is off the top of the graph! Either turn down the voltage of the 'power amp', or use the scale menu on the response plot so you can see up there.
To be completely accurate, you would need a zma file of the driver's impedance and a frd file of its frequency response. As default, XSim assumes a driver's impedance is pure 8 ohms resistive, and its response is flat with 70dBspl at 1V input. That will get you reasonably close on the effect of the crossover, assuming your driver is 8 ohms. If it is 4 ohms, just put another 8 ohm resistor across it in the model (but not in the actual crossover!)
Old 21st June 2016, 06:51 AM   #8
My woofer is 93dbl
I have download FRD file of 8" of SEAS. Mine is 10" SEAS.
Can you help me modify the graph?
I attached as ZIP file
My amp is 65 watts/Ch.
Old 21st June 2016, 10:30 AM   #9
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
You have entered in mod sensitivity the 93dB value which raised
the overall spl to a level that you can't normally see without moving
the vertical center of the SPL graph. Set it to 0 dB. Make a simulation
based on manufacturer's box volume of 28 litres and its sensitivity
plot at 0 deg which already has baffle step factored in. Trace the impedance
plot of the same box.
Mankind is created for eternity.
Old 21st June 2016, 12:33 PM   #10
I will try. Thank you so much Mr. Lojzek.
Low pass filter 10mH & 100uF what the freq cutoffHide this!Advertise here!
Low audio frequency cutoff filter Josetcr Analog Line Level 7 30th June 2011 06:22 AM
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
Capacitor to filter low freq buzz? steve71 Multi-Way 15 20th January 2009 05:48 PM
LM12 bridged sub amp with low pass filter steven344 Chip Amps 0 21st November 2005 04:31 PM
Copyright 1999-2017 diyAudio
