#11 |
I'm overwhelmed with concepts.
The wood work on those Karoliina monitors looks amazing. I'm getting a better idea of what I'm in for. Basically the music that I'm working on is complex. most of the tunes are ending up to be something like 32-34 tracks of stuff going on. Mixing is a nightmare Generally when I get it sounding good in the studio Mixes Played on everything else sound bass boomy with no mid frequencies. So I'm constantly second guessing with EQ . With the introduction of an AMEK Neve preamp everything changed. So my weakest link are my cheap monitors. I've seen alot of great systems using the Seas Drivers, perhaps a pair of those with a matched pair of tweeters I might be on the right track. Maybe have someone design a proper crossover. Thanx |
#12 |
karolina, fantastic woodwork. if you supplied these as a kit it would mean one would have to duplicate the wood work as well as the (complicated) crossover.
...still looking for the holy grail. |
#13 |
Maybe copy this
http://www.avalonpro.com/mixing_monitor.htm http://www.promoremusic.com/avalonpr...lonmonitor.pdf
Is that all there is? |
#14 | |
Take your best mixes and a selection of good sounding CD's into the studio. EQ your monitors by whatever means possible until they sound right. And then leave the settings there. If you can't EQ them for good sound you need new monitors. Neverless the the above process should be carried out. Only if you are really lucky will a pair of monitors sound correct without any EQ. (For a myriad of reasons). A good pair of monitors would just need some line level passive EQ tweaking. Easily, simply and cheaply done. |
#15 | ||||
My mixer is Behringer allthough I use mainly digital mixing inside the ST-Audio C-port audio interface Quote:
build and are quite expensive to build too. Lots of wood and MDF is required. And the building is slow. I did these with very primitive machines by the way. I didn't even own a good circular saw when I did these... Quote:
I was pretty succesful I must admit... Quote:
just solder the stuff and there it is.. The components used in the crossovers are by the way rather expensive since I don't use bipolar electrolytic condensers or ferrite coils. The air core coils add speaker's weight quite much - if I wasn't mistaken, there is something like 20 mH big (read expensive and heavy) air core coils for the bass driver. I have no good documentation of these yet, just some markings on paper with pen and the latest modifications to the crossover aren't documented at all. I must open the speaker to look what is inside to be able to document it. For that purpose on the other hand, I have done the rear panel removable with screws and accessing the bass cabinet (where the crossovers are) is possible. It may however take a while before I have enough energy to open all those screws since I tend to be lazy sometimes... Best Wishes, Karoliina |
#16 | ||
It would have been hardwork to get those flares for the tweeters accurately... Quote:
ajju |
| Studio Monitor Project - In Need of Advice | J.R.Freeman | Multi-Way | 12 | 20th August 2008 05:37 PM |
| GOOD SMALL STUDIO MONITOR PROJECT or KIT | Maak | Multi-Way | 9 | 7th November 2006 07:27 AM |
| Recommendations for an accurate, detailed, monitor design | Phlim | Multi-Way | 7 | 28th September 2006 07:38 AM |
| LDC Studio Monitor project | niallsmart | Multi-Way | 0 | 26th September 2003 03:31 PM |
| Page generated in 0.09801 seconds (77.63% PHP - 22.37% MySQL) with 10 queries |
