Okay, I swear I searched, but came up with nothing like this.
Why not use PVC tubing or Sonotube for mid enclosures, mounting the driver in one end and capping the other? With the proper size tubing, you get no baffle. Heck, you could even use progessively smaller tubing, mounting each inside the other, to taper the tube similar to how B&W does it. I know I am not a genious, and someone else has already thought of this or else there is good engineering why it won't work. So, enlighten me... David |
#2 |
Acoustically, you will still have a baffle of the size of the membrane, so you will not get rid of the baffle step in this way, if that was what you intended. But sure, it will be smaller than *any* other baffle that you can mount the driver in.
#3 |
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#4 |
frugal-phile(tm)
Better than capping the back is to make the tube the rigt length and make it into a relatively aperiodic TL.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Studio monitor speakers as Hi Fi speakers? | MRod | Multi-Way | 2 | 27th March 2009 05:07 AM |
| Built differences between Guitar Speakers and PA Speakers? | agadis | PA Systems | 7 | 24th September 2007 08:22 AM |
| How would you compare your DIY speakers to commercial speakers? | AJ Bertelson | Multi-Way | 20 | 28th May 2004 03:20 PM |
| Car Speakers in Theatre Speakers NEED HELP FAST!!! | Psionic | Multi-Way | 9 | 3rd March 2003 11:11 AM |
| Page generated in 0.06432 seconds (75.21% PHP - 24.79% MySQL) with 10 queries |
