Small Syns
Small Syns
Old 9th May 2018, 08:26 AM   #391
3ll3d00d is offline 3ll3d00d  United Kingdom
3ll3d00d's Avatar
decided to drill through as per instructions so hopefully get the drivers mounted this weekend and some measurements collected
Old 9th May 2018, 07:00 PM   #392
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Small Syns
Looks really good.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 15th May 2018, 09:06 PM   #393
3ll3d00d's Avatar
I got the drivers wired up, took on axis measurements and fed them into your xo design. Leaving aside the droop at the top end (and the fact I haven't taken off axis measurements yet), I'm not sure if it's a bit bumpier than the design, what do you think?
Old 15th May 2018, 10:48 PM   #394
3ll3d00d's Avatar
and with the individual responses
and the underlying raw data per way
Old 16th May 2018, 02:21 AM   #395
bwaslo's Avatar
Small Syns
The one at 100Hz is expected -- an interraction between driver/box/and inductors. Couldn't bring that down without clobbering efficiency. But then it's down where room interractions are at play so just another bump into the mix down there.
The one at 2kHz seems pretty high (and in a touchy place). Is your L2 inductor a particularly low-ESR part? You can try bumping R4 an ohm or so to bring it down.
Edit -- oop. Wrong version design. Try adding some resistance in series with L2 to bring down the bump.
Old 16th May 2018, 02:22 AM   #396
bwaslo's Avatar
Small Syns
But all told, not terrible. How does it sound?
Maybe Trim R6 (increase) a bit to raise midrange -- there is a diagram in the instruction PDF showing what some of the trim values can do.
File Type: png 53186FD4-D65B-4C23-B89A-966E81DBF6F2.png (98.5 KB, 134 views)
Old 16th May 2018, 09:14 AM   #397
3ll3d00d's Avatar
It's just in a sim atm so I don't have it to listen to yet unfortunately. I had seen the suggested variations so wanted to get it into a sim first so I could play around with that & also verify the result before I order the parts..
I intend to be crossing this to a (sub)woofer anyway so the peak at the bottom of the woofer is not a problem. The peak at 2kHz with the dip just beneath it was the bit that made me pause to wonder whether this is as per design or not.
what does C7/R3 do btw? IIRC removing it didn't seem to have much of an impact (on a sim with the on axis data only in that is).
Old 16th May 2018, 05:20 PM   #398
bwaslo's Avatar
Small Syns
c7/r3 are just shaping, they drop the bottom end of the cd down a little in level relative to upper end. Subtle effect
Old 16th May 2018, 06:00 PM   #399
bwaslo's Avatar
Small Syns
Got that backwards (having a bit of difficulty looking at things today) -- they drop the HF a little, sloping the overall response downward
Small SynsHide this!Advertise here!
Sell beatiful small 6F3 small tube amp (used like new) siliconray Vendor's Bazaar 0 1st March 2012 12:50 PM
Small room, small speakers advice c12mech Full Range 10 14th March 2011 08:36 PM
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
