Small Syns
Small Syns
Old 9th April 2018, 03:46 PM   #371
nc535 is offline nc535
that sounds more like an epoxy than a putty it will work but it may be harder to work with. the trick with these two part things is not to use too much of the hardener. If you do, then it will set so quickly you won't have time to shape it.
The plumber's putty OTOH never hardens; it can always be reworked. that's both its blessing and its curse
Old 9th April 2018, 06:54 PM   #372
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Small Syns
This is the water putty --
Durham's Rock Hard Water Putty
Neat stuff, the 2nd part is water. You keep adding water or powder until you get a workable consistency, then start packing it in. It sets in several minutes, then it is essentially a rock. I once thought about using it to mold waveguides.
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 9th April 2018, 07:13 PM   #373
3ll3d00d is offline 3ll3d00d  United Kingdom
3ll3d00d's Avatar
milliput seems to be widely used for modelling & sculpting and reportedly has a more clay like consistency which is workable for a decent period of time. I'll find out soon enough anyway.
Old 9th April 2018, 11:44 PM   #374
phivates is offline phivates  United States
Definitely pick an epoxy putty with longer open time. 20 minutes goes by in 10...
Old 15th April 2018, 11:09 AM   #375
3ll3d00d's Avatar
milliput seems to work well (at getting it on at least) and it certainly remains malleable for quite a while (with a wet finger to help), now to wait and see how it hardens
Old 16th April 2018, 02:23 AM   #376
bwaslo's Avatar
Small Syns
you're going to want to fill that cavity in to the surface of the wood mount (with about 1" paths to the ports) -- too much front volume (assuming you're using the TF0410MR midrange)
Old 16th April 2018, 07:05 AM   #377
3ll3d00d's Avatar
I added that as well, it has dried rock hard but was easy to mould. I can see why this stuff is used for sculpting.
Old 16th April 2018, 08:54 PM   #378
3ll3d00d's Avatar
I got the drivers mounted on the horn and plan to take some (no XO) measurements this weekend. I have measured Z on the horn already. Do you have any pics of that data from your original design? It would be nice to cross check against that as I guess that is the best way to tell the way the drivers are mounted is good.
Old 17th April 2018, 02:57 AM   #379
bwaslo's Avatar
Small Syns
Ok, dug these out. The midrange impedance:
The HF impdedance:
Old 17th April 2018, 07:46 AM   #380
3ll3d00d's Avatar
thanks, mine look similar to me so I suppose that's a good sign
Small SynsHide this!Advertise here!
Sell beatiful small 6F3 small tube amp (used like new) siliconray Vendor's Bazaar 0 1st March 2012 12:50 PM
Small room, small speakers advice c12mech Full Range 10 14th March 2011 08:36 PM
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
