Small Syns
Small Syns
Old 29th December 2017, 05:34 PM   #361
Cask05 is offline Cask05  United States
Cask05's Avatar
Too large.
Old 29th December 2017, 06:28 PM   #362
300Z is offline 300Z  Brazil
Send a message via AIM to 300Z Send a message via MSN to 300Z
Can also use any of the cloud storages to share the file, like MEGA or Dropbox.
Old 29th December 2017, 08:14 PM   #363
Cask05's Avatar
Be my guest...I won't get in your way.
It's also in Olson's Acoustical Engineering text, sections 5.29 and 5.30. That's also available online.
Chris
Old 3rd January 2018, 08:45 AM   #364
Ro808 is offline Ro808  Netherlands
Originally Posted by NEO Dan View Post
Can you attach a copy for those of us who do not have an account over there?
Here it is.
Old 3rd January 2018, 11:09 AM   #365
Cask05's Avatar
So if you consider a room corner as a secondary "manifold exponential" horn (i.e., exponential loading isn't necessary for loading, but the math is more straightforward in the Olson article) when a horn-loaded loudspeaker is placed near a room corner--especially one with a large horn mouth--then you might see that there is more gain or loss of throat loading at the off-axis woofer ports with a MEH-type loudspeaker in a room corner than with a direct radiating bass bin.
Old 3rd January 2018, 03:35 PM   #366
NEO Dan is offline NEO Dan  United States
NEO Dan's Avatar
Originally Posted by Ro808 View Post
Here it is.
Dan
Old 8th April 2018, 09:05 AM   #367
3ll3d00d is online now 3ll3d00d  United Kingdom
3ll3d00d's Avatar
Originally Posted by bwaslo View Post
When I was testing, I just used inexpensive plumbersí putty (from about any hardware store) and after getting it where it needed to be, left it in. Itís been ok for over a month now, so I think it will be ok for permanent use.
I am making a start on building these and had a question on this. Has plumbers putty been ok over a longer period of time?
Also re the ports, is the idea to keep the area approximately constant through the putty or is it expanding somewhat?
Old 8th April 2018, 09:07 PM   #368
grec13 is offline grec13  United States
One is ready, four to go!
Sergey
Old 9th April 2018, 03:43 AM   #369
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Small Syns
If i were to do it again, I'd use something like Rock Hard Water Putty or epoxy putty or bondo or the like (I used water putty on the ported versions). The plumber's putty hasn't given any problem to date, but that may not mean it never will, so no need to risk.
The ports in the horn are considerably smaller than the area leading down into them. Like this --
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 9th April 2018, 02:40 PM   #370
3ll3d00d's Avatar
OK thanks. I'm not sure what a UK equivalent of water putty is (nothing obvious leaps out from a search) so will go with a putty (like Standard Yellow-Grey Milliput - For repairing water and fuel systems, filling dents, modelmaking and much more.)
Small SynsHide this!Advertise here!
Sell beatiful small 6F3 small tube amp (used like new) siliconray Vendor's Bazaar 0 1st March 2012 12:50 PM
Small room, small speakers advice c12mech Full Range 10 14th March 2011 08:36 PM
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 07:51 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 02:07 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
