Small Syns
Small Syns
Old 16th March 2017, 07:43 PM   #311
bwaslo is offline bwaslo  United States
Old guy with soldering iron
bwaslo's Avatar
Small Syns
But nice and minimal looking, I like that. Though not if they fall over!
[W9MJE] Horn spreadsheet SynergyCalc/; SmallSyns SmallSyns;
Crossover design Xsim; Depot diffusor super-easy diffusors
Old 16th March 2017, 08:32 PM   #312
sphykik is offline sphykik  United States
Fortunately no kids or pets in my house so I'm fairly confident in them, for now at least!
Old 17th March 2017, 02:21 AM   #313
phivates is offline phivates  United States
Do you have thread locker or a lock nut on the woofer magnet damping pad?
Old 17th March 2017, 02:24 AM   #314
bwaslo's Avatar
Small Syns
I don't, but that might not be a terrible idea. The threaded rod is under some good pressure, though, and the friction between the pad and the back of the magnet will make it tend to not want to rotate. If you did use thread locker, I'd make it the 'blue' type so you don't lock yourself out of getting the threads free again down the road.
Old 17th March 2017, 02:30 AM   #315
Most of the old Japanese speakers I've dismantled had something to keep the fasteners from loosening. And yes on the blue, the red is serious about the locking.
Old 21st March 2017, 04:37 PM   #316
Over the weekend I cranked out two 48"x30" panels using Roxul Safe n' Sound. WAF is dropping fast! I might cut the height in half and then mount them on the wall.
I'm surprised by the difference these made - the imaging is insanely precise and being able to pinpoint exactly where toms are in space, as they pan from one side to the other, is quite gratifying.
Also, MiniDSP is on the way!
Old 21st March 2017, 04:49 PM   #317
mwmkravchenko is offline mwmkravchenko  Canada
Mark Kravchenko
mwmkravchenko's Avatar
Small Syns
Lookin right spanky!
Papa Waslo should be proud!
Mark
www.kravchenko-audio.com
Old 21st March 2017, 06:09 PM   #318
bwaslo's Avatar
Small Syns
Great photo there!
What MiniDSP are you getting? (if it's the 2x4HD, I can send you or post a linear phase FIR eq and/or a Linkwitz transform file for it)
Old 21st March 2017, 06:14 PM   #319
pcgab is offline pcgab  United States
Small Syns
Those look great, good work!
Old 21st March 2017, 06:28 PM   #320
Thanks all! There are a few wrinkles, but I'm going to live with them until I feel like pulling staples
Originally Posted by bwaslo View Post
Great photo there!
I got the 2x4HD and additional software package. If you could send/post both that would be great! I plan to learn how to use rePhase, but it would be helpful to have a starting place, and also a file to compare results against. Thanks Bill!
Small SynsHide this!Advertise here!
Sell beatiful small 6F3 small tube amp (used like new) siliconray Vendor's Bazaar 0 1st March 2012 01:50 PM
Small room, small speakers advice c12mech Full Range 10 14th March 2011 09:36 PM
small-signal (small-power) fast switching complementary transistors Lola Luna Solid State 3 8th April 2010 08:51 PM
Small-signal (or small power) pentode that can handle 400V (or more)? GordonW Tubes / Valves 12 13th June 2008 03:07 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 02:19 PM
Copyright ©1999-2017 diyAudio
