Hi.
I'm beginning whith mi first speaker diy project. I decided a pair of boxes about 14l. But I dude with the drivers. For tweeter, the VIfa XT25, cause range extension: the FS 500Hz permit easy crossover cut. For the mid-woofer, I like the detailed sound of hard cones (magnesium, fiberglass, kevlar...) about 6.5-7". The branches that I can buy here are Vifa, Peerless, Scan-Speak, Monacor & Focal. 50-100$. My candidates are: Peerless 850439 HDS 164: good frecuency response, without peaks. Good for my box volume, but less diameter than the others, perhaps few bass? Vifa PL18W0: good volume box too, but the paper cone... Vifa MG18 or XG18: really like this drivers, But their Vas are high. Do you think the correct volume box is a minor problem? Any other driver with fiber glass or similar with low Vas? Thanks. |
#2 |
Peerless drivers are renowned for their excellent bass performace, the 850467 HDS w/phase plug is not exemp from this it gives out good wallop. So then would the HDS w/out plug.
The XT25 is a deceptive beast, yes it has a low fs and high power handling so you would think it can do low xovers, but from what I have seen posted about this driver is it most definately sounds better the higher you cross it.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#3 |
for your first project you should use any one of the umpteen
designs available for 6.5"/1" combination of drivers. For hard cones try this : http://home.hetnet.nl/~geenius/DD8.html Your very, very, unlikely to design better than this first attempt. Its fairly straight forward to adapt to internal volumes 10L to 20L and various other bass alignments types. Though for subwoofer use I advise a very compact sealed box. Note that the impedance compensation is optional, Ls,Cs & Rs, and I can't see the point of including it. |
| Choosing drivers. | gvr4ever | Multi-Way | 4 | 12th September 2006 02:18 AM |
| Choosing Drivers for DPKSPKII | DPK | Multi-Way | 0 | 16th February 2005 09:58 AM |
| Choosing Compression Drivers | Pbassred | Multi-Way | 21 | 6th September 2004 02:46 PM |
| Choosing Compatible Drivers???? | Gavinator68 | Multi-Way | 3 | 19th March 2004 01:31 PM |
| Need help choosing 3-way drivers | AudioIsFun | Multi-Way | 7 | 3rd January 2004 04:03 PM |
| Page generated in 0.08039 seconds (72.43% PHP - 27.57% MySQL) with 10 queries |
