Came across this impedance phase plot on another thread:
http://www.speakerbuilder.net/web_fi...ct/erosmk2.htm The speaker's impedance pahse plot, including the crossover region, seems to stay between -75º and -120º from 80 Hz all the way up to 20,000 Hz. Is that a normal phase impedance plot?
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
#2 |
Here is the impedance plot.
#3 | |
#4 |
What makes you think that this is a plot of phase? I think the phase plot will be a Hilbert transform of that magnitude plot, since there no reason for this to be anything but minimum phase. The builder's claim of a 12.5 degree max phase angle should be easy to check by differentiating the magnitude plot with respect to frequency.
Svante, yes, there is a port in the mechanical drawing.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#5 |
The plot is the magnitude of the impedance, phase is not shown.
It would be a very unusual phase plot. Above 80Hz it is +/- 12.5 degrees according to the text. It is a reflex so goes to 180 degrees in extreme bass. |
#6 | |
The reason I thought it was a phase plot was that degree markings are given on the right hand side.
#7 |
Phase goes through zero degrees at the peak of "macro" slopes It goes up as the slope of the impedance magnitude curve is increasing and down as the slope of the impedance curve is decreasing. The rate of rise or descent is dependent on the slope change of the impedance magnitude.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#8 | |
Artifact of the software. It probably defaults to that format as "plot paper" capable of plotting two functions, and the guy who posted it didn't do whatever it takes to display the phase curve on the same plot. One tipoff is that there's always peaks in a magnitude plot, and these translate in the phase plot to something that looks like an S turned sideways, with the center of the S crossing zero degrees at the same frequency as the magnitude peak. No S curves crossing zero degrees, it ain't phase.
#9 | |
#10 | |
I might as well bring this question up. The major differences between passive and active crossovers, as I understand it, are: A) The DC resistance of the crossover components, mostly inductors, and their effect on the damping of the drivers; B) Massive irregularities in phase response compared to active crossovers. Well, A can be addressed with quality inductors. The cost should not be prohibitive in the 2,000 Hz frequency range. If the crossover was down around 200 or 300 Hz, that would be a different story. B looks like it has largely been solved. Plus or minus 12 degrees is not that far away from zero. If that claim is true about the impedance phase curve, would it be fair to say that this speaker, with it's passive crossover, should give overall response very, very close to that of an active crossover? If not, where would the major differences lie?
| Impedance phase plots - 4 ohm drivers | fb | Multi-Way | 1 | 17th August 2008 08:07 AM |
| take a look at my fr plots and tell me what you think about that null | pjpoes | Multi-Way | 14 | 19th July 2008 02:44 AM |
| Need help with impedance curves and FR plots... | fjhuerta | Multi-Way | 13 | 8th April 2006 08:57 AM |
| Sensitivity vs Impedance Plots? | johninCR | Multi-Way | 5 | 24th November 2004 12:40 AM |
| Measuring phase & impedance w. PC soundcard? | Ultima Thule | Multi-Way | 3 | 19th September 2004 10:01 PM |
| Page generated in 0.10223 seconds (80.88% PHP - 19.12% MySQL) with 11 queries |
