SEAS A26 in oversize cabinet
Old 15th May 2016, 10:46 AM   #1
nugat is offline nugat  Europe
Default SEAS A26 in oversize cabinet
I ordered the SEAS A26 kit (mid woofer and tweeter) and am about to build the cabinet (aperiodic) which is specified at 28 l. volume.
I'm mostly after the above 80Hz spectrum as the bottom two octaves are taken care of by my distributed bass system.
I've been thinking of increasing the cabinet volume but mostly for the soundstage enlargement sake, not bass.
I will appreciate any thoughts, opinions, advice on this idea.
Real life experience cases also appreciated.
Old 15th May 2016, 03:09 PM   #2
R.I.P.
I'd stick to the specified design. Not much to be gained here.
However you could turn it into sealed and stuffed floorstander,
just by extending the specified box downwards, should be fine.
Adding some bracing would be a good idea.
rgds, sreten.
Old 16th May 2016, 01:59 AM   #3
system7 is offline system7  United Kingdom
system7's Avatar
Here is an established variant in a bigger closed box. Must be 50-60L or maybe more. The Vas/Qts calculation gives you a whopping 85L.
Designing Loudspeakers - WD25T EX - The next step
Devore Orangutan Clone?
Best Regards from Steve in Portsmouth, UK.
Old 16th May 2016, 02:48 AM   #4
system7's Avatar
Peter Comeau did a bit more than I thought there. It is about 60L, but he has placed an aperiodic vent half way down the closed cabinet.
He must know what he is doing.
http://user.faktiskt.se/M_N/WD25T_Part1.pdf
Reduces the stuffing required, and it works as bracing too.
Old 16th May 2016, 06:21 AM   #5
irext is offline irext  Australia
irext's Avatar
Hi Steve. Thanks for the link to the WD25T EX. I am quite interested in this build as I am quite a fan of the Devore Orangutan which I heard at a HI FI show a year or so ago. I thought it was the "best in show" at the time and was very impressed with its ability to make any recording come alive. I've been looking at the Seas A26 kit but I like the idea of a slightly taller larger enclosure. The second link you gave didn't work for me (said I didn't have access) I assume it had the cabinet details. Do you have the cabinet details in another format.
Cheers : Ian T.
Old 16th May 2016, 07:02 AM   #6
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Scott & i did this revistion of a classic TL for these drivers.
http://p10hifi.net/tlinespeakers/FAL...visited-WD.pdf
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 16th May 2016, 01:45 PM   #7
I am interested in using the new A26 kit with the new T35C002 tweeter (and A26RE4 paper mid- woofer). In the 28L box Seas designers propose to cross them at 1500hz with a simple
high pass filter (1 cap, 1 resistor). The midwoofer works full range.
I really like the simple crossover idea and would like to preserve it in a bigger cabinet.
My goal is to have the speaker work nicely with my distributed bass system (4 subwoofers)
and take over from ca 60-70 hz.
The thing I'm really after is bigger soundstage than in the 28L box.
Do you think I can simply enlarge the cabinet to 60-70 litres and keep the original A26 drivers/XO setup? The only parameters to regulate would be the resistor value and stuffing
(or lack) of the aperiodic slot.
Old 16th May 2016, 02:59 PM   #8
system7's Avatar
Of course, nobody knows what crossover is in the Orangutan. But a 10" bass and a low crossover tweeter just play nicely together.
Peter Comeau does a more sophisticated filter than SEAS, and a better sounding one from my experiments. I think it is marginally changed by the bigger baffle, perhaps on the crossover null particularly, but hardly audible I'd think. Varios Excel SEAS tweeters were used over the years, people have even used metal ones.
Here's the build pdf for the WD25T EX. I don't have the tuning up Part 2. Planet 10's transmission line must be good too. People always make out transmission lines are hard, but they all look the same to me.
Old 16th May 2016, 04:04 PM   #9
R.I.P.
Hi, IMO speaker volume has little to do with soundstage size, rgds, sreten.
Especially in the case of subwoofers and satellites.
SEAS A26 in oversize cabinetHide this!Advertise here!
SEAS A26 Speaker Kit HiFiHarry Multi-Way 62 28th December 2017 06:07 AM
Seas A26 aperiodic bracing & damping gerben00 Multi-Way 23 21st September 2016 02:43 PM
Is it possible to Oversize an SE OPT? NewMountain Tubes / Valves 0 22nd October 2012 11:27 PM
Oversize PCB causes problems. wakibaki Parts 3 19th November 2008 04:51 AM
Need to oversize trafo? PederBass Solid State 6 30th April 2004 12:16 AM
