"Dainty" loudspeaker parameters.
Old 21st March 2004, 07:48 AM   #11
iyo is offline iyo  India
hi everyone,
the dainty drivers that are available in INDIA are not
mentioned on the dainty website.the importer
told me that the modls were made according to his specs(doubtfull!!!).
thanx
Old 17th June 2004, 11:21 AM   #12
pat_staunton is offline pat_staunton  India
Default Dainty Specs.
Hey does any one have an idea of the specs. of this particular driver from Dainty?
SL1030B 120 Watts RMS 8 ohms.
Or any idea where I could get them from?
Well thats it for now..
Old 17th June 2004, 04:00 PM   #13
ashok is online now ashok
ashok's Avatar
Default Dainty specs
The Dainty brand couldn't have too many drivers.
Did you check http://www.diyaudio.com/forums/showt...717#post352717
It has two 30cm drivers listed on it. Most probably one of them will fit probably your model number.
1030 indicates a 30 cm driver.
Plesae guys , SEARCH the forum before posting. The Archives have become huge and you could find some ( plenty ?) info on it. Saves everyone else some time.
Cheers.
AM
Old 25th June 2004, 04:47 AM   #14
dumrum is offline dumrum  India
dumrum's Avatar
Has any one been able to measure the TS parameters for the Daintys.
And if yes, do the measured parameters match the ones we have got here posted in the Excel sheet?
Linoj Job.
Old 3rd July 2004, 02:19 PM   #15
nareshp is offline nareshp  India
Default Re: Rehashed specs.
Originally posted by ashok
I took time off to put up IYO's Dainty specs in an XLS spread sheet. This time hopefully you guys will get it intact.
Looks like some drivers are going to be useful in dipole subs. I expect the Qts to be higher than specified and this would be very good for a dipole.
Cheers.
Hi guys,
Greetings! new here and I need some help. I just picked up a Dainty sub model SL820SSP but I have got no specs nor does their site have any. Would also like to have the dimensions for a sealed box for the SL820SSP.
Old 4th July 2004, 03:50 AM   #16
ashok's Avatar
Look at http://www.diyaudio.com/forums/showt...717#post352717
SL0820 probably applies to your model also.
AM
Old 4th July 2004, 04:20 AM   #17
Thanks.The box that the SL820SSP came in says it is an 8ohms driver.
Old 1st September 2004, 06:38 PM   #18
darrenjpinto is offline darrenjpinto  India
Send a message via MSN to darrenjpinto Send a message via Yahoo to darrenjpinto
Dainty speakers are available at the following place in Bangalore:
Globe electronics, Sadar patrappa road or SP road as everone knows it. dont buy from anywhere else as their prices are from the retail list and they are the dealers.
enter sp road and take the second left, it is a narrow gully and you will find the shop on the right. These guys also are dealers for bolton and phillips.
darren
Old 16th September 2004, 08:18 AM   #19
Roypaul is offline Roypaul  India
Default Dainty T/s parameters test
Dear friends I am Roy paul from Trivandrum. Yesterday I purhased a 10 " Dainty Sub250spp 8 ohms version subwoofer from Casafonics for Rs 630/-. Acualy I want 12 " sub, since he dont have stock with a condidition that he can replce if I not stisfied with 10". Then I tested with my computer sound card and amplifier configuration this 10 " sub. The first cut the values were not maching the one somebody posted in this site. Whereas the values were maching more closely for the SUB300SPP 8ohms version.
The values I got for 250SPP Rdc --> 6.1 ohms
Qts --> 0.44/0.43
fs --> 27.38 hz. Vas : 44 Liters
Now I am given a order for 35 liters sealed Box. When it comes next week I can feedback.
Thank U.
Old 16th September 2004, 01:28 PM   #20
ashok's Avatar
Hi Roy,
Don't worry if the published spec does not match with what you've got. Just make sure you have measured it properly. If need be use two different methods to measure it. There is enough freeware to do that. If you are on track, the two readings should be reasonably close .
Remember that the values will change a bit as the driver runs in.
Fs will surely drop a bit. That will result in changes in Vas and Qts.
Neverthless you need to start somewhere . Get your box and start experimenting. For ducted enclosures , make sure you can alter the duct size . Gives you some flexibility while experimenting.
Search the forum for more threads on the topic. A lot has been covered.
Have fun.
AM
"Dainty" loudspeaker parameters.Hide this!Advertise here!
"compact loudspeaker factory visit from "magico mini" thread Nanook Multi-Way 2 4th January 2008 07:30 AM
what makes a loudspeaker "full range"? kneadle Full Range 25 15th April 2005 07:53 PM
Defining a "Good" Loudspeaker ThorstenL Multi-Way 11 25th June 2004 04:22 PM
Has anybody used Dainty 2" tweeter goldyrathore Multi-Way 0 8th March 2004 11:59 AM
