2.1 build, bluetooth - diyAudio
Old 7th May 2016, 02:11 AM   #1
Default 2.1 build, bluetooth
I am looking to build a Bluetooth cube with one 5.25" sub and two small speakers.
I had originally started a thread here 8" sub choice for "small" Bluetooth system
Based on that I have bunny trailed a bit and am building a small system of 2 4" cubes that are coupled together, but can be split for better sound using the 3" TB's.
However back to my original idea. A decent sub in the smallest box possible and two good drivers with it. I'm looking at the Tang Band sub http://www.parts-express.com/tang-ba...eaker--264-917 because it takes a very small box and has decent output. .1cuft box sealed
I am thinking of using 2" speakers
http://www.parts-express.com/fountek...river--296-725
I like these because they .01 cuft sealed box or smaller and works well from 800hz up.
Right now I am thinking of about a 7" sealed cube.
It would be cool to have access to a speaker store to just test and build... I find stuff works out different in real life than designed in my head.
Old 7th May 2016, 02:52 PM   #2
picowallspeaker's Avatar
Fountek FR58EX 2" Neodymium Full Range Speaker Driver
Well 800 hz seems too much, 80 Hz being better as uniformly adopted around the globe. Even 60-70 Hz but no more than 100 Hz .
Those little 2 inches are 15 W; I don't know your usual playing volume and they might be ok from normal to loud in a room - At loud volume the magnet starts to warm a lot- considering a metal box to help to dispose of it
Of course they need to be filtered from frequencies below 100 Hz ( it's written 130-20000 hz linear operation ; you might consider a 3 " for an extra octave ) as well as the subwoofer.
Everything under and above heaven is in utter chaos
Old 8th May 2016, 04:20 PM   #3
Ok I originally wanted to use the Tang Band W3-881SJF 3" Full Range Speaker and cross them over at 100hz to the sub Tang Band W6-1139SIF 6-1/2" Paper Cone Subwoofer Speaker
I was unsure the 3" TB's could do 100hz well so I was looking to cross higher and use smaller speakers. If the TB's can handle crossing at 100hz in a sealed box I think that configuration would sound better, and the box would not have to be that much larger.
Old 9th May 2016, 09:24 AM   #4
Can the 3" TB's handle being crossed at 100hz? and would these two make a good pair?
I read somewhere it is good to cross slightly inside the rating of the speaker. The 3"TB's are rated from 100-20,000 HZ.
I don't want to invest all that money if they don't match well. If they do I think they would sound amazing.
Old 18th May 2016, 12:03 PM   #5
After looking at the final box dimensions and driver frequency plots I don't think I want to go with the W3 and W6.
I am now looking at using 5.25" TB W5 (ported) and the 2" TB W2 and crossing them higher in the 5-800 HZ range This would give me a cabinet size of around 9x14x7.5 that is very close to the size I am looking for.
Should the 2" TB's be ported for this style or would they be ok sealed?
Old 18th May 2016, 12:23 PM   #6
Naaaaahh! It doesn't work like that ! You've gotta do some research what a subwoofer is supposed to do; I mean, you can go ahead your own way and have your 5 1/4 " working till [ insert good linear passband response till it drops natuarally] but usually it's no good having the two channels mixed mono
when they are supposed to work in stereo.
It's related mostly on how different frequencies change dispersion ( or beaming ) and also, for the woofer, changes from omnipolar to directive in semi-space ( the baffle etc. )
Old 18th May 2016, 12:50 PM   #7
vuki is offline vuki  Croatia
vuki's Avatar
Hi maxximus,
friend and I are planning to do something similar to what you decided to do; and choose exactly the same drivers (1xW5-1138 & 2xFR58ex - planning to xover them at cca. 250Hz). I decided to use some 2.1 tpa3116 based amplifier and 24v switcher PS. Bluetooth car media players also look suitable. I hope to pack everything in 25cm cube.
Old 18th May 2016, 01:04 PM   #8
Vuki
Awesome. Are you porting the 2" drivers?
I would think 250hz is to low a crossover point unless they are not going to be driven that loud.
Old 18th May 2016, 01:16 PM   #9
vuki's Avatar
I plan to put them in a closed volume and I guess a pair could do cca. 90dB/m.
Old 18th May 2016, 05:40 PM   #10
mondogenerator's Avatar
Default Cool and doable - within reason
I have also thought about a similar build or two.
I planned to use a reasonable woofer 5-6", like Mission CP168 paper cone woofer (laying about here) and visa ton frs5x 2" cone midtweeter and it looks ok in simulation corrssing the HP filter at 5-700Hz 4th order. It is SPL limited though, and I plan to try three of the frs5x instead to give better headroom.
The other build is a W3 with lower xmax than many. Safest bet for me here is HP at 400 Hz and again 4th order. But I lack the right woofer, 8" or larger.
Or....there's the Alpair 5 and some 10" bass guitar speakers I have left over from a dead cab....
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Using bluetooth intensate Class D 6 26th November 2015 09:09 PM
Bluetooth Aptx Bengali Digital Source 4 11th June 2014 03:30 PM
Another Bluetooth question Rick B Class D 7 5th November 2013 12:02 AM
Bluetooth Speaker (Build Log) MatthewP Everything Else 0 4th November 2013 08:39 AM
Tips On Bluetooth Stereo Build funkdoktor Construction Tips 0 2nd August 2012 10:10 PM
Copyright 1999-2017 diyAudio
