Two midbass drivers in one box - diyAudio
Old 27th April 2016, 10:26 AM   #1
bego2 is offline bego2  Croatia
Default Two midbass drivers in one box
Hi guys, I have a few questions about building a speaker towers with two mid bass drivers and tweeter. Two mid bass drivers im planning to use are identical. There is a few things that I dont understand, if i have two identical drivers how do I connect them, I would use 8 ohm drivers, so parallel, thats 4 ohms, than how I make crossover? Like i would make for 4 ohm driver or? And the question about TW, Is it a problem to use a 8 ohm TW here, because I have two at home. Any suggestion ?
Thanks.
Dance4Life
Tiesto4Life
Old 27th April 2016, 11:22 AM   #2
TMM is offline TMM  Australia
Send a message via AIM to TMM
Yes for a 2-way design you would wire them in parallel to achieve a nominal 4ohm load, then you would design the crossover as if it were one driver with half the impedance.
It is no problem to use drivers with different nominal impedances in the same speaker as long as you design the crossover filters to suit each driver. You will also have to deal with the different sensitivities of the drivers.
Note that even though your drivers are 'nominal' 8ohm, they may not actually be 8ohm at the frequency you wish to cross them. The most simplistic way of dealing with this would be to inspect the impedance graph in the datasheets and use the impedance at the crossover frequency to use in your crossover filter calculation.
Old 27th April 2016, 06:35 PM   #3
eriksquires's Avatar
Hi Bego,
I suggest you play with XSim, it's a crossover simulator that is a great way to learn and try out different configurations. You can get data files from Dayton on their drivers and try to create virtual speakers to learn about the process and parts, without spending any money at all. For instance, your questions about impedance, and series vs. parallel could be tested out there.
Using the ZMA (impedance files) you can also learn about the complexities of driver impedance, and how it all combines with a crossover for the final impedance curves.
Best,
Erik
All of my successes and failures can be explained by my attempts at getting a girlfriend. All of them.
Old 27th April 2016, 07:27 PM   #4
thanks guys, in those two answers I have everything I need to know. I now about sensitivity. cheeeers.
One more Q. Im thinking to buy these drivers, two per box.
http://www.visaton.de/en/chassis_zub...n/w170s_8.html
What do you think for a box volume? I want it to play from 40ish to 4000hz... dance, hause, vocal music, trance..similar music...
Dance4Life
Tiesto4Life
Old 28th April 2016, 12:10 AM   #5
norman bates's Avatar
well, 2 x 8ohm drivers now seem to be +6db with the same 2.83v.
so the 2 of them (in parallel) look like a 4ohm driver with 92db.
Since running them in parallel and stacked (not mtm), I'd cross definitely @ or below 2khz.
floppy qts on the driver.
I'd assume 5mm xmax.
if the specs seem true, 2 of them go into a 3.2ft3 box (91 Litres) and have an F3 around 49hz.
If you want to go deeper but have less output before bottoming out the drivers, you could do 6ft3 tuned to around 28hz.
Old 28th April 2016, 12:57 PM   #6
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Hello countryman!
I have been working with Visaton W170 S-8 once and I still have the
measured TS parameters. Use simulation software like UniBox
or Jeff's Woofer Box Model and Circuit Designer.
software
Being good or bad is just a matter of practicing habits, good or bad. Once you get used to it, it's easy.
Old 28th April 2016, 09:46 PM   #7
that sounds great, I have monacor dt-254 twiteer that plays good from 2k hz
MONACOR - Products: DT-254
Originally Posted by Lojzek View Post
Hello countryman!
software
Thx Lojzek, that helped toooo
Dance4Life
Tiesto4Life
Old 28th April 2016, 10:23 PM   #8
with a qts .67, you'd need a way bigger box for ideal.
Forget ported for them.
sealed 3ft3 might give a bit of bump under 100hz, you'd have to run the simulations.
But that bump may give the impression of less lower bass.
np. what we do here.
Old 30th April 2016, 09:27 PM   #9
So what you said about 3.2ft3 box (91 Litres) you meant a sealed box?
Dance4Life
Tiesto4Life
Old 1st May 2016, 05:39 AM   #10
Yea, it's smaller than ideal, but you don't usually have much choice with high qts drivers.
TAD midbass box recommendation homebuilder Multi-Way 19 17th September 2015 04:05 PM
FS: Two Tang Band (TB) W6-1721 7" Underhung Midbass Drivers - New In Box! opc Swap Meet 6 18th June 2012 01:02 AM
Two Old 6.5" Midbass Drivers...what to do with them? form109 Multi-Way 34 24th January 2010 05:21 PM
2.5 way with different midbass drivers pjpoes Multi-Way 11 26th June 2008 09:06 PM
2 way with large midbass drivers? FE3T Multi-Way 0 4th November 2006 12:01 PM
Copyright 1999-2017 diyAudio
