Old 26th February 2004, 09:42 AM   #1
Question equivalence electric and mechanical (acoustic) correction SPL
I have some loudspeaker with a few not large peak and hole (or other non-flats) in SPL-diagram. I use graphic or parametric EQ for correction and get flat SPL. Is it indeed equivalence?
EQ utilize not only because non-flat initial SPL, but also for correction room response.
Old 26th February 2004, 10:01 PM   #2
Correcting speakers electronically is equivalent to crossover correction.
But a good loudspeaker design will not include room corrections,
so these corrections have no equivalence.
sreten.
Old 26th February 2004, 11:10 PM   #3
Bill Fitzpatrick's Avatar
I fully agree with sreten but take it a step further - I would not correct for the room with an equalizer.
I'm sure you want to know why so I'll tell you.
I want the wave front that travels from the speaker directly to my ears to be as close as possible to the output of the amp. If there are problems with the room they should be corrected by modifying the room, its contents, or by altering speaker/listener placement.
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 02:38 PM
F/S Brand New Taylor 712CE acoustic electric guitar (Natural) davismark Vendor's Bazaar 0 17th December 2008 09:06 PM
Combined acoustic/electric rolloff niacin Multi-Way 9 14th June 2007 10:02 PM
mechanical hum Bill*B Tubes / Valves 4 30th May 2007 09:42 PM
Mechanical ear purplepeople Everything Else 1 5th February 2005 02:40 PM
Page generated in 0.06649 seconds (70.15% PHP - 29.85% MySQL) with 10 queries
