Hi All - I recently came across a pair of Zenith Allegro 3000 speakers at a thrift store. They have (supposedly Fostex) 16 ohm, 10" Alnico woofers and a horn tweeter. I'd read on a few forums that these are very efficient and they ARE much more efficient than my Advents. Does anyone have any specs for these or actually measured them. I'm guessing they might be 96-98 db/w/m. Is that close? I took the backs off, as someone suggested, but I'm wondering if anyone has tried these in a different enclosure. If so what design and dimensions? I'm thinking of eventually building something that's simple (since I'm not much of a carpenter) and is efficient enough for my DIY "budget Bugle" 45 SET that I recently completed. Any info or suggestions would be greatly appreciated . . . Charlie
#2 | |
frugal-phile(tm)
The samples i have are more like 88-90 dB efficient. I've kept 4 10s for my own use and will build a bipole something with them. The horn is a Foster and really quite nice, dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
just a thought,
but refurbishing the original cabinets seems the the best option to me, the speaker is still original. |
#4 | |
frugal-phile(tm)
Stock the speakers sound bad... take the backs off and it opens up a whole new world... put the drivers in a real box and they start to sing. dave
#5 |
I thought both the drivers might be by Foster(ex) because they both seem to use the same numbering system. The tweeter is labeled Foster and 49-1168 while the woofer is marked Zenith but numbered 49-1240 and also 26322 and 2857419. Maybe the last number is the Rola number. Out of curiousity I dropped the woofer into another, slightly larger, bass reflex cabinet. I also tried it alone in the Allegro cabs by just disconnecting the crossover/tweeter. The woofer alone did not seem to be nearly as efficient as the combo and wasn't all that impressive by itself. I 'think' the Advents are about 88 db (maybe I'm wrong?) and the Allegros are quite a bit louder but they aren't nearly as extended in the bass or as refined in the highs as the Advents. I guess that shouldn't be too surprising. They do sound better with the back of the cabinets removed. Has anyone built any cabinets for these? If so, what design and dimensions?
#6 | |
frugal-phile(tm)
dave
#7 |
I got the same project im mind, keep checking my thread in case your interested.
http://www.diyaudio.com/forums/const...ml#post2169564 |
#8 |
wow, this is an old thread! I just got done pulling the guts out of one of these (will do the other tomorrow) I was wondering if somebody might be able to give me some info on the drivers if I post some pics... they do not look like the woofers you posted. but I do think they are from 1970.. the last 4 didgits are 1270..if I'm not mistaken they woulod have been made the 12 week of 1970? anyway I hope somebody can give me some info on the drivers..
#9 |
I'm wondering if it is OK to use a pair of these with my home theater receiver and additional (different) speakers. The other speakers are rated 8 ohms. Do you know the impedence of these Zeniths?
tweeter - Foster 49-1168 74.22 woofer - 49-1240 26322 2857428 gizmo on the side of the speaker cabinet - S-97277 Thanks!!! |
#10 |
frugal-phile(tm)
16 ohm drivers
Data on the 4 pair i've had thru here. You can use it for a 1st pass at an enclosure dave
| Zenith 12" alnico cabinet suggetions | sawdude | Multi-Way | 5 | 8th January 2009 05:36 PM |
| Zenith Console find, amp suggestions? | Eratosthenes | Tubes / Valves | 8 | 28th August 2008 05:20 PM |
| Cabinet varnish suggestions | lmcmaju | Multi-Way | 3 | 9th September 2004 03:30 AM |
| What speaker specs for a free air install (aka car door)? and other suggestions | MITMechE | Multi-Way | 2 | 11th May 2002 09:52 PM |
| Page generated in 0.12365 seconds (79.47% PHP - 20.53% MySQL) with 11 queries |
