Project Small 2-way OB On a Budget - Need advice!
Old 6th March 2016, 02:34 PM   #1
cowfoot is offline cowfoot
Default Project Small 2-way OB On a Budget - Need advice!
Hello diyaudio,
i have been lurking around here for quite some time, but this will be my first post on here.
I have been inspired by all the beautful pictures in the "Ultimate OB gallery" thread and want to build a OB speaker. The thing is that i have limited space and money, so the size and price of the speaker has to be kept down. Im quite new to speaker designing and need some advice and help to reach my goal.
As of now i have done simulations based on the T/S parameters (using BoxSim) utilising the Eminence Delta 12A-2 and the MarkAudio CHR-70.3. The simulation results look like this;
Frequency response:
Project Small 2-way OB On a Budget - Need advice!-fr-graphe-png
I think the frequency response looks good, i know the efficiency isn't skyhigh. Will the impendance peak around 500Hz be a problem?
Off-Axis Frequency Response:
Project Small 2-way OB On a Budget - Need advice!-fr-angles-graph-png
I think that the horizontal off-axis response is acceptable. But the vertical response isn't that nice looking. How important is the vertical off-axis responce? Is the dips in reponse around 700Hz a consequence of the crossover topology? Any ideas to how to fill the dips around 700Hz? Will physical time-alignment of the drivers help regarding the vertical off-axis response?
Crossover Design:
Project Small 2-way OB On a Budget - Need advice!-crossover-png
Critique?
Old 6th March 2016, 05:44 PM   #2
diyAudio Member RIP
Boxsim can't model open baffle loss AFAIK.
The resistors on the bass unit are a very bad idea.
Look at :
http://www.quarter-wave.com/OBs/OB_Design_Part_1.pdf
http://www.quarter-wave.com/OBs/OB_Design_Part_2.pdf
rgds, sreten.
Old 6th March 2016, 06:22 PM   #3
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
High fr driver doesn't seem to have any directivity in the plot - There is something basically wrong there. But I believe that this is doable.
AINOgradient speaker project
Old 7th March 2016, 01:15 AM   #4
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
If you're not set on the drivers you mentioned, you might have a look at this: Fast, fun, Inexpensive OB project - Page 46 - diyAudio
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Project Small 2-way OB On a Budget - Need advice!Hide this!Advertise here!
Woofer selection advice needed for ENDORPHIN P17 OB project. beano Multi-Way 9 29th July 2015 12:19 AM
Driver advice for small simple OB speaker RobFreak Full Range 15 27th January 2014 01:19 PM
New Alpair 7, small OB project Monte Verdi Full Range 52 31st October 2012 10:48 PM
First desktop OB speaker project (need advice) colinwen Full Range 12 18th April 2012 10:10 AM
Need active amplification for OB project, what's the latest and greatest on a budget? architect7 Class D 0 3rd December 2011 02:50 AM
Copyright ©1999-2017 diyAudio
