adding magnets
I've got a couple of old 8" drivers whose cones have suffered from too much wine spilt on them, kid's fingers etc i.e. the cones are stuffed, but they've got big magnets which can be unscrewed.
Rather than ditch them, I was wonder what the effect would be of simply sticking these magnets on the back of some good drivers?
Increased sensitivity???
or is this just a silly idea?
Pete McK
I do know what happens when you do this kind of thing to a DC electric motor - it runs slower for the same applied voltage because it always tries to rotate at whatever rpm that generates the same as the supply voltage.
Translate that into loudspeaker-speak ;) it means that if you double the magnet strength the sensitivity to drive voltage drops by 3db (perhaps 6dB?) This is because the voice coil impedance doubles. You have double the flux on the same length of wire. It is the same as the same flux on double the length of wire. If you also reduce the length of voice coil wire by the amount you increased the magnet strength, then... :smash:
But the glued on magnet is not part of the magnetic circuit ?
(Presume that the pole pieces are removed)
Glued on in opposition to the stray magnetic field in will cancel
a lot of it, if its too strong, most of its field will be cancelled ?
By making the stray field magnetic path "harder" you will get
a minor increase in the flux of the magnetic circuit ?
This is how I understand bucking magnets to work, and that
they are required in fully shielded drivers to prevent the steel
screening can magnetically saturating due to the stray field.
:) sreten.
Yeah, I was more talking about if you actually increased the total magnet strength, which you would not do just by putting another magnet on the outside. You would have to remove the back pole plate and put the new magnet directly in contact with the original one then put the pole plate back on, as you implied.
I was raving on about sensitivity because a stronger magnet seems to do the opposite of what you would expect.
You would also need to extend the centre
polepiece by the thickness of the magnet.
However this relatively simple engineering expedient is used.
But the magnetic circuit and the magnets cannot support the
doubling of flux, the whole thing is not optimally designed.
Some point of the magnetic circuit is forced deeper into saturation.
(Ceramic magnets are flat shaped, to give more area for the flux)
You can make the gap slightly longer, but not a lot.
Nevertheless Vifa for one use double magnets in some of their
drivers, presumably because engineeering wise its simple to
do, and there are some advantages.
But the magnet circuit design is sub-optimal.
Also your DC motor analogy must be flawed. Practical experience
shows that the more flux you have, the higher the sensitivity.
Taken to its logical limit - you need tiny magnets for high sensitivity -
and we all know that this simply isn't true, you need big magnets.
:) sreten.
There are several thing that happen when you apply an extra magnet to an existing speaker driver.
If you mount it the way it has least resistance, ie in phase, you actually in magnetic flux loss, because the voice coil gap where the flux is intended to be concentrated is usually above the the existing magnet mounting another magnet in phase will pull magnetic flux away from the voice coil gap thereby decreasing the flux strength in the voice coil gap. Mounted this way will also result in increased stray magnetic radiation.
If you mount it the way it has most resistance the opposite will happen. The magnetic flux centre point will be pushed nearer towards the voice coil gap thereby increasing the magnetic flux strength in the voice coil gap. Mounted this way will also reduce stray magnetic radiation.
Almost all parameters of a driver is interdepended this means if the magnetic flux strength is changed almost all parameters of the driver is changed as well. And since it is almost impossible to predict how much the flux will change, having access to measurement equipment would be a nice thing.
As a general rule when the flux is increased though sensistivity will go up along with fs. Vas and Qt will go down however.
This most often has the result that bass and midrange will sound more controlled and with much improved definition. I wholeheartedly recommend it for basically every speaker driver. I know it's one of the first thing I do when I get a new driver, it almost always improve the driver over stock ones.
Please note that you should never mount a magnet that is bigger than the original magnet as this can have very unpredictable results.
sreten said:
Sorry, but I can't see how Fs or Vas could possibly change.
Yes, I know that theoretically they shouldn't as neither parameter is directly controlled by the flux density. But it is my experience that it does. Only slightly though.
I believe it may be because the voice coil contains a slight amount of magnetic material and thereby decreasing Cs (and all parameter connected with that), but this is only my best guess.
NOTE EDITED
just thought i'd add something to this topic'
i had spare sub lying on my floor a wile back and one day i decided to move it cos it was in the way' i put it on top of one of my surround speakers(two 4 inch mids and a tweet) witch is on a stand,
i didnt really take much notice for about two weeks then one day i put on a dvd and i thought the other surround speaker wasn't working but infact the sub on the other one was making that one about double the volume :confused:
so its my conclusion that it increases sensitivity a lot in small mids and such but in larger speakers that already have large motors the effect would be minimal especially to the ear:)
sreten said:
Also your DC motor analogy must be flawed. Practical experience shows that the more flux you have, the higher the sensitivity. Taken to its logical limit - you need tiny magnets for high sensitivity - and we all know that this simply isn't true, you need big magnets.
Increase the magnet strength and the dB output for a given =wattage= will increase, no problem, I agree there, but at the same time the dB output for a given =voltage= will decrease. This is because the voice coil impedance increases with increased magnet strength.
With nothing else changed:
For a fixed voltage drive, the stronger the magnet the quieter the speaker.
For a fixed current drive, the stronger the magnet the louder the speaker.
You could try this with an old electrodynamic speaker that has a big electromagnet on the back.
Yeah, but the back EMF of the driver is neglible over most of its range so it's practically current controlled. So sensitivty will increase(in the flat part of the speaker's response, but as the Q decreases the sensitivity at resonance, where the back EMF is bigger, will decrease.
I just did a simulation where Bl of a driver was changed from 1 to 8, Rms (and Qms) was kept constant. Constant voltage drive was used.
It appears as if the output level increases with voltage a bit above the resonance.
diyAudio Moderator Emeritus
Joined 2001
Great chart, Svante! :up:
So, the way it works is, double the Bl through a larger magnet and your midband sensitivity goes up 6 dB, but your Qts decreases, (which might not be a bad thing if you haven't built your cabinet yet).
In fact, increasing the Bl from 4 to 8 seems to decrease the Qts from something around 1.1 all the way down to something around .28. Wow.
I got those approximations from judging the SPL at resonance to the SPL at the midband.
Thanks Svante for actually proving my percieved and experienced changes.
I should note that it's basically impossible to double the magnetic flux or Bl unless you actually take the original magnet out and replace it with neodymium ones instead (And that doesn't work as well as one would expect :D )
The realistic increase for a 'back-mounting' an addition magnet is around 10% to 25%.
