I am a newbie, so hi to all,
Let me drop a bombshell for debate and see what emerges after the dust settles. I am looking for a DIY speaker that works especially well for home stereo use. I am looking for a two or three-way speaker for under $500 (the pair) that delivers audiophile quality sound for music listening. Bass must go low, be well defined and provide a smooth and detailed transition from bass to mid and from mid to hi. I am looking especially at ported tower designs. I mostly listen to jazz and classical but do delve into an occassional romp with vintage Led Zep' or Queen. I will be using a good quality Sansui or Carver stereo receiver rated at 60 to 120 watts per channel. What recommendations do you all have? As usual, any and all opinions are welcome. Randy |
#2 |
Id say take a look at this site:
http://home.hetnet.nl/%7Egeenius/index.html some great designs by someone who really knows what they are doing. |
#3 |
frugal-phile(tm)
His Solo 103 is one i'll probably inspire one of my designs...
Back to the case at hand... doing a well executed mini-monitor with a pr of separate subs have huge advantages.... lots of mini-monitor examples at the above link and there is a Focal-based LS3/5A clone out on the net that looks interesting... not to mention the Vifa P13/tweeter combo, or any decent small FR with a helper tweeter (the last being the approach i'd take) Those 2 receivers will limit the audiophile capabilities of any system -- unless the Sansui is a heavily tweaked ols tube unit. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Banned
I'm going to have to agree here.. that this link to this site is really Great.. i like all the project's OHHH FOCAL Yumm!
http://home.hetnet.nl/%7Egeenius/index.html |
#5 |
diyAudio Moderator Emeritus
I like the look of his Auriga speakers:
http://home.hetnet.nl/~geenius/Auriga.html Interesting use dual 7" drivers, one in a sealed part of the cabinet, and the other ported. I have never seen this done before with identical drivers. -- Brian |
#6 |
Banned
Looks to be a nice design and Clean looking.. wonder what the cost is to build these..
#7 |
Also checkout this site :
http://www.speakerbuilder.net/web_files/default.htm The designs are more in line with the amplication capabililties,and in some cases a lot cheaper. I like the retroness of the Lyra, which looks ideal, if a subbwoofer is not part of the equation. |
#8 | |
the Mission 753. The top two drivers are internally boxed off with vertical and horizontal sections and only the bottom two are reflexed. The 753 is also a high sensitivity 0.5 way, using the lower bass units for Baffle Step correction of the higher units. |
#9 |
Banned
| Please recommend two ceiling speakers for under £100 | SimontY | Multi-Way | 3 | 10th June 2008 05:02 PM |
| Coworker looking at Bestbuy Speakers, recommend PartsExpress. | Hybrid fourdoor | Multi-Way | 7 | 13th March 2005 01:09 PM |
| DIY Speakers: Ultimate for $600 recommend | Haknhendrix | Multi-Way | 15 | 11th November 2003 08:44 AM |
| Page generated in 0.11999 seconds (77.99% PHP - 22.01% MySQL) with 11 queries |
