I have an old pair of KEF Concertos that I refurbished about eight years ago putting in new tweeters and good quality crossover from Wilmslow Audio. While they sound OK I have always fancied using the drivers (KEF T27, B110 and B139) in the Cambridge R50 TL speaker. HiFi Anwers did the plans for a version of these speakers in the 1970s.
I will shortly have the workshop facilities for making these complicated speakers and am looking for a set of plans that I can use to build them from. Has anybody any idea where these would be obtainable? I note there is a book on speaker design that mentions projects from the 1970s but do not know if it covers this sort of design. RV |
#2 |
we all have problems only some people have more than most.... long live the Magyar (Hungarians) in the world! |
#3 |
Going back a bit here, the Bailey design also used the same drivers.
The Hi-Fi Answers design is called the Pro9-TL I believe. The seminal design using these drivers is Linkwitz's active 3-way, which was the basis for the passive KEF 105's. And I'm sure there are IMF designs not too far away. JMO but bass obviously will be better, mid/treble ? why better ? And you need to make sure that if you buy crossovers they are for the correct versions of each drive unit. KEF were (in)famous for using versions of drivers in their speakers that were not made available to home constructors, and it is also sensibly rumoured the units made available were production rejects, AKA the Constructors series. Years ago, and I mean it, I converted a KefKit3 (the same as the Concerto) to a smaller satellite stood on top of the original bass enclosure, other than not retuning the bass reflex, I still think this is the sensible option, midrange, imaging and detail improved immensely. From what I remember a prominence in the B110 around 1k is actually improved by the much smaller baffle, a premise that at the time KEF would not confirm but did not deny. If your interested I can describe further details. |
#4 |
#5 | |
agree- the Pro9-TL was a kneejerk that was wrong, still trying to remember the TL design using two HF1300's. The problem with the LS3/5A B110 was the required specs ended up being to one side of the bell curve, i.e. lots of rejects. But I still think a large and complex TL enclosure will not improve the Concerto's mid / treble performance one iota, and that such effort is misguided. |
#6 | ||
frugal-phile(tm)
![]() Quote:
My feeling would be that given we have much better TL modeling tools would be to grab Matin King's software and generate a new line for the B139 -- i'd also TL load the B110... ideally an active XO at about 200-300 Hz between the B139 & B110 (point choosen so as to deal with baffle step). Of the classic lines, Bailey's Triangulated TL was always my fave. dave dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 | |
#8 |
PS; thanks planet 10 for posting that diag saves me having to dig mine
#9 | |
frugal-phile(tm)
Note: i don't know if i was an influence, but Bud Fried started making his sats a similar shape, after i'd had clients build Fried Hs with the "pyramidal" sats. dave
#10 | |
frugal-phile(tm)
dave
| Looking for answers | JamesBob02 | Everything Else | 2 | 2nd March 2007 07:27 AM |
| I need some help and answers!! | chops | Tubes / Valves | 14 | 7th June 2003 01:50 PM |
| Page generated in 0.12383 seconds (85.54% PHP - 14.46% MySQL) with 11 queries |
