Do I have to use a sealer first on the mdf then primer or just the primer ?
The sealer I was thinking of using is watered down pva glue Or is there something else I can use that is cheap. Thanks |
#2 |
Did it Himself
Buy MDF primer. I think you can mix PVA with water-based wood primer too, or maybe it's 50/50 water/PVA...
Anyway, don't try using 'normal' primer on MDF. I did, and I used about 3 times more primer than necessary because it just soaks it all up. I have also tried car primer in an aerosol and that was even worse. |
#3 |
marine resin works really well
#4 |
Where can you get MDF primer? I've already soaked 2 cans of automotive primer into my .2 cubic foot MDF boxes, and I've still got a LONG way to go at this pace.
#5 |
I heard using artist's Gesso paint (used for priming canavas) for primer was the way to go for MDF.
#6 |
I've had good luck with a 50-50 mix of water and regular yellow carpenter's glue.
| Paint Cracks in MDF Painted Boxes | slhijb | Multi-Way | 7 | 9th October 2006 03:24 PM |
| Paint steel chassis with the "aluminum paint" used on wire fence? | vax9000 | Tubes / Valves | 2 | 23rd July 2006 01:14 AM |
| wood undercoat under auto paint ? | busterno1 | Everything Else | 6 | 8th March 2004 04:24 PM |
| Page generated in 0.08916 seconds (75.77% PHP - 24.23% MySQL) with 10 queries |
