New Project Beta 12LTA Fostex FT17H in a TQWT
Old 21st February 2004, 11:57 AM   #1
MIKET is offline MIKET  United States
MIKET's Avatar
Send a message via Yahoo to MIKET
Default New Project Beta 12LTA Fostex FT17H in a TQWT
Just starting up my new speakers, Beta 12LTA Fostex FT17H in a TQWT. I found this drwing posted for the TQWT on the net at
http://home.pacbell.net/tullius/home5.html
but the site is now gone.
What do you think?
Old 22nd February 2004, 03:17 AM   #2
GM is offline GM  United States
GM's Avatar
I think you need to study up a bit on Ml-TQWT theory and use MJK's Mathcad worksheets to design a much better one: http://www.quarter-wave.com/ Of course post Qs here as required to get through it, and unless it just needs to be short, then a straight untapered pipe with a standard round vent will work fine with this driver and be much easier to build/tune.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 22nd February 2004, 03:18 AM   #3
MIKET's Avatar
Default furtue details
I intend to epoxy Oak or maple stuts to stiffen the frame since it is stamped metal and cover the whole mess with Mortite to deaden it. The crossover will be the same as
http://melhuish.org/audio/super12.html
Cabinet constructed from Baltic Birch
Puzzle Coat on the cone, dammar on the wizzer.
Caps by Mundorf.
#14 wire for inductors.
Old 22nd February 2004, 03:26 AM   #4
MIKET's Avatar
GM
I don't have or can afford Math Cad, The drivers specs are at :
http://www.partsexpress.com/pdf/290-409.pdf
Can you possibly run the numbers? If not then I guess I will be going with what I have.
They are sitting in the closet waiting for warmer weather. As soon as it is tolerable in my garage I will be out there sawing som plywood.
Old 22nd February 2004, 03:47 AM   #5
GM's Avatar
There's a free demo version on his site you can use, though you can't save the design. FWIW, ebay usually has older versions dirt cheap: http://cgi.ebay.com/ws/eBayISAPI.dll...&category=3789
GM
Old 22nd February 2004, 04:02 AM   #6
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
I ran some numbers for this driver a while back, since it is relative inexpensive from PE. I found that it required a huge enclosure to get a good response from. Here is the response that I got from a 9.32 ft^3 enclosure (35" high internally, 450 sq in cross-section)
Here is the response that the ML TL mathcad sheets give me:
Brian
Old 22nd February 2004, 04:03 AM   #7
BrianGT's Avatar
Here are the numbers that I used for running this:
Brian
Old 22nd February 2004, 04:05 AM   #8
BrianGT's Avatar
I ran some numbers on the cabinet referenced in the first post, and it doesn't seem to go very low. The driver really needs a large enclosure to have good bass response.
Brian
Old 23rd February 2004, 11:11 AM   #9
MIKET's Avatar
Default Box designed on MLTQWT worksheet
Here is what I came up with unfortunately with a 6" vent 1.5 " deep as calculated by WinISD the vent Mach would be .07 and a frequency of 37.05 Hz which is a bit high. Going to a rectangular vent of 5" X 12" rectangular 6.25" deep gives the same frquency but a vent Mach of .03" see below.
Old 23rd February 2004, 12:25 PM   #10
MIKET's Avatar
Default VOIGHT variation on above
What do you think?
New Project Beta 12LTA Fostex FT17H in a TQWTHide this!Advertise here!
Fostex FE127e. Eminence 12LTA. nodiak Swap Meet 4 4th January 2009 05:30 AM
Where to find Fostex FT17H in or near the UK? bigwill Multi-Way 12 14th June 2008 07:00 PM
Phase plug for Beta 12lta JimW Full Range 1 21st April 2005 01:07 PM
FS: Fostex FT17H Illusus Swap Meet 2 6th March 2005 11:46 PM
Eminence Beta 12lta Glenn Swiderski Multi-Way 5 9th December 2003 02:31 PM
