#11 |
Is this what I see there?
#12 |
Try this setup: (yes this is the worst thing I have ever drawn!)
If it sounds good... it is good! |
#13 | |
#14 | |
Anyway, I have my dipole subs wired in parallel for a 4 ohm load and they are very detailed, however they are also wired out of phase with one driver facing forward and the other backwards. On the other hand, my car audio system has a single 12" driver with dual 2 ohm voice coils wired in series, also for a 4 ohm load. This sub is very clean and detailed sounding as well. I don't know. I have never done a side-by-side test to see if series or parallel sounds better.
Charles |
#15 |
I fixed it for you.
#16 |
Speakerholic
The woofers are wired in series, it is a 2nd order parallel Xover.
The black wire on the left hooks to the negative. The patch wire from the (+) to the (-) is only taped to the cap, no connection. The white wire from the orange cable goes goes through the coil and hooks up with the cap and the(+) terminal. The other end of the cap goes to the original (-) input. A simple 12dB parallel cut-off Mark: I can't wire the drivers in parallel, these are 4 ohm woofers and I don't want to run 2 ohms. I think I am going to grab a beer and try a series network on them to see if that changes anything. Cal |
#17 |
Speakerholic
Well I didn't get through the beer before I realized I was heading downstairs for no reason.
Anyone want a laugh at my expense? Now's the time. lol! Cal |
| Three 10" 4Ohm subs, wired in series or series-parallel? | Nagamitsu | Car Audio | 24 | 10th May 2009 03:24 AM |
| Series vs Parallel for dual Accuton Woofers | Cousin Billy | Multi-Way | 15 | 25th December 2008 05:59 PM |
| 2 Woofers in Parallel Config - 4 Options | HiFiNutNut | Multi-Way | 16 | 23rd November 2006 03:23 PM |
| LM3886 GC + Behringer + Parallel woofers Q | PeteW | Chip Amps | 0 | 4th April 2005 06:55 AM |
| unidentical woofers in series/parallel? | Jay | Multi-Way | 5 | 25th January 2004 09:18 PM |
| Page generated in 0.09804 seconds (74.77% PHP - 25.23% MySQL) with 11 queries |
