Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better?
Old 20th February 2004, 08:41 PM   #1
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Default Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better?
Hi everyone,
I'm not sure about anyone else but I don't seem to have much luck when I run two 4 ohm woofers in series. It seems to change the sound. I don't mean that it's quieter, I mean that it seems to lose some of the bass altogether and gain some in the mid. I recognize the change in impedance will alter the Xover point but I just seem to lose bass. I am using a 6.2 mH choke in series and a cap across for a 2nd order.
When I parallel two 16 ohm woofers, not only do I get an increase in the volume, but the overall sound doesn't seem to change. I don't have a scope or an SPL meter to check.
I would like to keep my impedance at 8 ohms.
Do I just live with the fact I enjoy the parallel circuit more and be done with it or is there more I should know?
Thank for your help
Cal
Old 20th February 2004, 08:45 PM   #2
markp is offline markp  United States
Its the series inductance of the voicecoils that changes things. In series each woofer see the source resistance and inductance of the other woofer. Use a parallel setup for 8 ohms from 2 16s.
If it sounds good... it is good!
Old 20th February 2004, 08:49 PM   #3
coolkhoa is offline coolkhoa  United States
coolkhoa's Avatar
Send a message via AIM to coolkhoa Send a message via MSN to coolkhoa Send a message via Yahoo to coolkhoa
Default Re: Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better?
Cal [/B]
How many times have you wired 4-ohm woofers in series? If your claim is the result of multiple experiences, I must take it seriously...
KTK. Kool To the Kore.
Old 20th February 2004, 08:52 PM   #4
Also with 2 woofers in parallel you get a 6db increase relative to a single driver. Half the impedance = 3db and two drivers producing the same sound = 3db.
Old 20th February 2004, 08:59 PM   #5
Speakerholic
Cal Weldon's Avatar
Car audio woofers are often 4 ohms and quite inexpensive. When I run them on a house system, I prefer 8 ohms. So I series them. My big ones are that way, so are the 4 dual 10 cabinets on top.
Here they are again,
Cal
Old 20th February 2004, 09:04 PM   #6
officeboy is offline officeboy  United States
Send a message via MSN to officeboy
Hah, you just like to show that picture..
Old 20th February 2004, 09:14 PM   #7
woody is offline woody
Cal,
Could you be wiring them out of phase ?
Old 20th February 2004, 09:15 PM   #8
R.I.P.
My opinion is two 4 ohm in series with one driver reversed and
connected out of phase is the best arrangement for 8 ohms.
sreten.
Old 20th February 2004, 09:17 PM   #9
Speakerholic
Cal Weldon's Avatar
You're right officeboy,
I waited twenty five years to get that set up, and now I want the whole world to see.
Look at me, look at me!
But seriously, I have that problem everytime I do two in series. Just last night I did an experiment with the biggies and once again I am not as happy as I should be. I rewired and swapped woofers etc. The big ones actually sound better with only one 4 ohm woofer hooked up.
What a guy to do?
Old 20th February 2004, 09:21 PM   #10
Speakerholic
Cal Weldon's Avatar
They are not out of phase.
When you wire these out of phase you are left with nothing more than a great big midrange. A crappy one at that.
This is the wiring
Two 4 ohm woofers in series or two 16 ohm in parallel. Which is better?Hide this!Advertise here!
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 38 19th February 2014 11:16 PM
Series vs Parallel for dual Accuton Woofers Cousin Billy Multi-Way 15 25th December 2008 05:59 PM
2 Woofers in Parallel Config - 4 Options HiFiNutNut Multi-Way 16 23rd November 2006 03:23 PM
LM3886 GC + Behringer + Parallel woofers Q PeteW Chip Amps 0 4th April 2005 06:55 AM
unidentical woofers in series/parallel? Jay Multi-Way 5 25th January 2004 09:18 PM
Copyright ©1999-2017 diyAudio
