For 10 years or so , I have used telephone 10 or 20 pair internal distribution cable as very low inductance speaker cable.
For performance/economy I don't bother to go elsewhere. Does anybody use this, and how do you find it to compare to reasonably priced purpose built speaker cable ? Regards, Eric. |
#2 |
Good choice! Just run several "pairs" in parallel and you get a pretty darn good transmission line.
I like CAT5 networking cable (24AWG solid core) for a more modern approach. Extremely low cost. jh |
#3 |
I have a bad experience with multiple stranded cable as speaker cable. The inductance may be low but the capacitance increases enormously. That leads to loss of detail in the high frequencies. It also might damage the amplifier due to parasitic oscillations.
#4 |
Banned
Give leroy a medal! He understands L vs C in cables.
Hmmmm.......... 2 medals in one day. Must be getting easier in my old age. [joke]. Jocko |
#5 |
Very good choice, Eric!
using something similiar: a twisted pair of Tefcel-insulated copper wire which is NOT tinned or silvered out the outside, pure copper only. Sounds gorgeous. From own experiments, i have abandoned multistranded wires, be it for speakers or interconnects and i use wires as thin as possible. Inspired by Allen Wright's cable cookbook, i use foil/ribbon conductors if i want to maintain both cross-section ultrathin in atleast one direction and required cross-sectional area for low resistance. I tried this out: 0.1mm thin EMC-shielding copper foil (i insulate it with PP adhesive tape) vastly outperforms the telephone wire if the system's resolution level is high enough. The copper foil is thin, has about 1mm˛ CSA. If you care about µphonics, choose the self-adhesive variant used for quick-building prototype PCBs and glue them to the floor
Greets, Bernhard |
#6 |
Banned
You guys are pulling our legs. No one would go to the trouble to make his own cable when he could spend thousands of dollars for someone elses cable based on some wild theory of the month.
H.H. |
#7 |
Jocko is on a roll !
How about cash rewards with your medals? Jam |
#8 |
Bernhard,
I agree with you. I have had good results with unwrapped foil inductors. I you insist on buying your cables try the Analysis Plus cables.Check out their web site. Jam |
#9 |
Banned
Maybe I'll give out some 2SK147 violets.
Or maybe a gym sock, formerly owned by Carl Zappa, and still damp. [joke] Jocko |
#10 |
Mrfeedback
I've used the same thing, but, you need to keep them short if the amp. can't take hi C loads. Not a problem for amps with good stability. Have you ever looked at this cable with a TDR (Time Domain Reflectometer)? 8 ohms for 25 pair cable, very interesting
What ever makes the tunes flow |
| Views on QED Silver Anniversary XT Bi Wire Speaker Cable | mixter_v | Multi-Way | 13 | 31st August 2008 09:33 AM |
| Amp4 Mod Round-up – Input wire, power caps and high capacitance speaker cable | Peteruk | Class D | 10 | 4th April 2007 06:12 PM |
| speaker cable from PC network wire | Hugo Rodriguez | Multi-Way | 4 | 6th September 2005 08:07 PM |
| How to wire a Ixos Gamma 7 bi-wire cable | mangalchacha | Multi-Way | 1 | 13th April 2005 02:58 PM |
| which is better line level cable/speaker wire | jonz | Everything Else | 1 | 18th October 2004 03:20 AM |
| Page generated in 0.14167 seconds (67.01% PHP - 32.99% MySQL) with 11 queries |
