I want to do a ML-TQWT with two 3" drivers in a MTM alignment. Line length will be 16". The distance between the 3" drivers is ~ 5". So its no "point source" anymore. Would a simulation with Martin Kings worksheets still give meaningful results?
How about the input values for the worksheet? Since the 3" are wired in parallel, I have to double Sd and Vad and halve Re. But I am not shure about Lvc, BxL and the Q-factors. Thanks for some suggestions Rudolf
www.dipolplus.de |
#2 |
Martin addressed this in an article on his web site.
Two drivers in TQWT You have the basics correct. |
#3 |
Thanks Timn8ter,
should have looked at MJKs site in the first place. Seems Iīm getting too lazy. But I am still not shure, if the distance between the drivers in such a short line could be an issue. Anyway, I`ll get some ply tomorrow and give it a try Rudolf
www.dipolplus.de |
#4 | |
#5 |
Sorry, the drivers are only 2" and the distance is 5" center to center.
Itīs a fixed system - an acoustically sound implementation of dīAppolitos theories. You see it in my first post. Obviously itīs only useable up from 100~200 Hz. More details are here: http://www.speakertrade.com/site/pro...roduct=Mmhe280
www.dipolplus.de |
#6 |
Ah, I see. That's interesting. Part of the ML-TQWT theory is to place the driver at the point of the 3rd harmonic. I'm wondering if you use the center point between the two drivers for that.
#7 |
That is exactly what I will do. I look at the system as a "very narrow" 8" woofer with the tweeter in the center. The weekend will show,whether this is right.
Thanx for your help. Rudolf (Youīve got a very attractive hometown. Been there - loved it!)
www.dipolplus.de |
#8 |
Hi Rudolf
Are you going to use teh MHE 280 MK II "Mittelhochtoneinheit " in your ML TQWT with the Gradient ??
There is NoBox like NoBox |
#9 | |
I will put the Mivocs on top of small dipole subwoofers. Itīs the most far out combination I could imagine for a small room - so I had to do it. It will look somewhat like this (yes, itīs still another ML-TQWT - with a Fostex FF 85K): Regards Rudolf
www.dipolplus.de |
| tqwt | kenneth | Multi-Way | 1 | 2nd October 2006 08:51 PM |
| TQWT (again?) help | Zen Mod | Multi-Way | 4 | 30th May 2006 05:40 PM |
| Looking for help with a TQWT box | xbofmnx | Multi-Way | 8 | 14th April 2004 08:37 PM |
| my first ml tqwt | Tomac | Multi-Way | 15 | 13th March 2004 03:06 PM |
| Ml Tqwt | masummo | Multi-Way | 2 | 12th January 2004 06:54 AM |
| Page generated in 0.10066 seconds (77.02% PHP - 22.98% MySQL) with 11 queries |
