I am looking for info on the "rules" so to say, about the effeciency of a midbass/woofer and a tweeter.
When selecting drivers for you speakers, do you need to keep the effeciency as close together as possible? Or is it all a matter of personal taste in sound. Any help is appreciated. If there are other thread please direct me there although searches on the subject have come up empty. |
#2 |
Speakerholic
Hi Ryan,
Methinks the rules of what you speak are really up to you. If you get a tweeter with a higher efficiency and you like the sound, leave it. If you feel it's a bit bright, you have the option of adding resistors to attenuate it. These resistors can be static or you can use a variable resistors such as L-Pad's. If you have a woofer that is too strong you will likely have to use your treble control or equalizer to attenuate as adding resistance loads to a woofer "kind of " defeats the amplifier power. Most of the power in audio is used up in the bass. Do you know what your tastes are as far as the brightness is concerned? I thought I liked it bright until I got a 108dB @ 1W compression driver behind a horn. I had to add an 8 ohm resistor in series and then a 5 ohm in parrallel just to bring it down to a decent level even though the woofer is high also at 97 dB @ 1W I think you are best to get a tweeter that is equal to or somewhat above the woofer so that attenuation, if required, can occur within the high frequencies. Hope this helps Cal |
#3 |
In addition to what Cal says, one of the most important issues in a better design is how baffle step compensation will be accomplished. If you are cutting down the upper range of a midwoofer for BSC, then you can effectively use a tweeter with a lower efficiency. If you are using multiple midwoofers, you must ensure your tweeter will match their effective (including crossover)sensitivity.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
| Dynaco A25 drivers. Four woofers, 2 tweeters. | nodiak | Swap Meet | 1 | 8th December 2007 04:33 PM |
| F.S.: (2)15" Magnavox Woofers and (2)Tweeters | Sal Brisindi | Swap Meet | 1 | 1st September 2007 02:26 PM |
| Korean Woofers/Tweeters | caratje | Multi-Way | 8 | 28th January 2005 01:44 PM |
| Matching Ribbon ( planars ) with cone woofers?? | JinMTVT | Multi-Way | 3 | 15th October 2004 09:23 PM |
| FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers | cm7 | Swap Meet | 0 | 1st August 2003 01:59 PM |
| Page generated in 0.08380 seconds (73.80% PHP - 26.20% MySQL) with 10 queries |
