Old 19th February 2004, 01:52 PM   #1
zuki is offline zuki  United States
Default who makes this 11" woofer ?
http://www.northcreekmusic.com/Drive...on_and_amp.jpg
Old 19th February 2004, 06:56 PM   #2
frugal-phile(tm)
planet10's Avatar
I've seen similar baskets on both Vifas & Seas...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th February 2004, 08:12 PM   #3
on the north creek site.
the sub claims an fs of 11 hz.
in a small sealed box.
any guesses on model/brand name ?
thanks
Old 19th February 2004, 08:36 PM   #4
frugal-phile(tm)
planet10's Avatar
If it did you'd need a million watt amp to get anything out of it -- you can't break hoffman's iron law
dave
Old 19th February 2004, 09:31 PM   #5
Send a message via AIM to ScottRHinson
Default Re: who makes this 11" woofer ?
That frame and surround color indicate to me that it might be made by Hi-Vi, or Dulcet or whatever name they are going by now. I have some of their drivers with a similar ribbed frame and a weirdly green surround material.
Scott
Old 19th February 2004, 10:13 PM   #6
Tensop is offline Tensop  Lebanon
Wow,
an 11" woofer with a resonant frequency of 11hz? in a sealed box?
the basket and spider looks similar to vifa woofers, however there is a third rib on each of the bars going from the surround up to the motor
and vifa use metal around the magnet to cancel the field dont they, faraday cage style... however thats using another magnet... in all honesty it looks like a chinese/taiwanese woofer
Old 19th February 2004, 10:54 PM   #7
wingman is offline wingman  Denmark
thanks
Link ?
bass is also audio
Old 19th February 2004, 11:02 PM   #8
i am wrong.
i guess i got dia of woofer wrong with fs
it is 14
Poseidon Woofer Theile-Small parameters:
Re = 6.24 W
Fs = 14.9 Hz ± 1.5 Hz
Qts = 0.28
Qes = 0.31
Qms = 2.89
Vas = 4.00 cubic feet (113 liters)
Sensitivity = 87.9db (2.83V, 1 meter)
H = 22.2mm (voice coil height)
G = 10mm (gap height)
Xmax = 13.9mm p-p
http://www.northcreekmusic.com/Drivers/Poseidon1.htm
Old 22nd February 2004, 12:18 AM   #9
someone checked
and north creek said they make them themselves.
Old 22nd February 2004, 01:23 AM   #10
frugal-phile(tm)
planet10's Avatar
someone checked
Possible, but not likely... they may design them themselves, but i betcha some OEM is buildin' them.
dave
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
What makes Nichicon "muse"/"for audio" caps different ? percy Parts 2 3rd October 2009 05:53 PM
What makes a speaker "tube-friendly"? Wally Tubes / Valves 53 13th March 2009 02:21 PM
what makes a loudspeaker "full range"? kneadle Full Range 25 15th April 2005 07:53 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
Page generated in 0.11369 seconds (75.81% PHP - 24.19% MySQL) with 11 queries
