I got a pair of new JBL Control 1 Pro (5" 2-way) and did some listening and also some measurements with REW. For my instrument application there is a problem with distortion, just at certain frequencies. For example, right around 200 Hz is bad spot, where I measure about 25% THD with a pure 200 Hz tone at around 90 dB SPL @ 1 meter. This is when driving about only 1 watt. You can hear the harmonics pretty readily. I tested both speakers of the pair. If you back off the level, the distortion goes away. Offhand seems unreasonable for a quality speaker rated at 150W RMS.
But maybe I'm wrong. Is this normal? Are all drivers around this size going to perform this poorly distortion-wise, or is the JBL design just an anomaly? If I were to build a cabinet (e.g. stock parts from parts-express), would stepping up to a 6.5" or 8" solve this issue? Or is it not related to size?
Background: I'm selecting speakers for an 8-channel+sub audio system for a virtual pipe organ at home. All channels with have full parametric EQ available. Because of the quantity, I was hoping to spend only around $80-$150 per speaker, and also I have space constraints. In this application, too much distortion would color individual notes and ruin the realism. I need about 105 dB SPL output per speaker, similar to the JBL spec. The sub will handle everything 100 Hz and below.
